I was wondering...
A DixV (.avi) movie that is ripped from a DVD has already lost its good quality... That's a fact.
If I wanna re-encode this .avi to DVD again, does it make any noticeable difference if I use 1 pass instead of 2 or 3 passes?
(Always using CinemaCraft)
VBR encoding in CCE is 1+n. There is always an analysis pass, plus the number of passes you specify. In my experience 2 passes is a minimum for VBR in CCE. 3 passes adds a level of refinement that can reduce some of the mosquito noise that CCE can accumulate. After than I believe you are pretty much spinning your wheels for no real visual gain.
That said, unless you are doing a little clean filtering in avisynth or virtualdub before encoding withh CCE, 2 passes is probably more than enough.Read my blog here.
Read my blog here.
From a mathmatical standpoint (according to a stats person I chatted with once) doing more than 5 passes is a waste of time.
Any changes made after the fifth pass should be so little that it would make no visual discerning difference.
When I say 5 pass I do mean 1 pass + 5 passes for 6 total.
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 12:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 17:51 -
Cinema Craft Encoder Issues converting to 16:9 etc.
By lapetite_66 in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 21:09 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 17:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 19:05
