Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 14 of 14
    Oct 2006
    Hi!
    This is my first post.
    I'm thinking of buying a player capable of playing XVID files. If I burn an AVI-file and a SRT-file with the same name as a DVD data disc, the dvd player should now show the subtitles as well ,right?
    I've seen on the internet that some players do this. But I'm not sure if all do. Is SRT part of the XVID standard? If not how can i find out if the player I'm thinking of buying can show SRT subtitles?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Maybe, or you have to select the .srt (having any name at all) before selecting the XviD AVI.
    Many, but I'm sure not all.
    No. It's no standard at all (neither is XviD).
    By reading the specifications, the manual, and reviews here and elsewhere on the web.
    /Mats
    Dec 2004
    Australia
    There is no XVID standard. XviD follows the MPEG-4 Part 2 standard. The MPEG-4 standard also covers subtitles, but that has nothing to do with srt's, avi's, etc. or most SAP's since most don't play mp4's and those that do would be Nero Digital Certified and Nero Digital uses VOBSubs as a private stream rather than ttext subs.
    You could burn a disc and test.
  4. Get a 5960 at circuit city. Its under $60 today. Shucks, a few days back it was under $40. It has USB & other stuff. Plays SRT & also .sub
    Oct 2006
    Thanks guys!
    Your answers made things clear for me. Although I hadn't see the acronym SAP(standaloneplayer) before. But that explanation I found with google. 8)
    Sep 2006
    Am thinking of doing this will this work on Playstation 2 the same way? if i name the srt the same name as the movie it sould load automatically it does with PowerDVD7
    Profoundly deaf.
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    A stock PS2 doesn't play AVI at all. If you have a chipped PS2, it depends on what app you use to play the AVI. SMS (Simple Media System) do both .srt and MicroDVD .sub, and use the "same name" method for matching AVI to subtitle.
    /Mats
  8. check out this guide, just tick the features you want and hit ok to narrow down your list (sub/idx is a feature you may want too along with PBS(packed bitstream))
    http://www.divx-compare.com/section-1-lecteur-dvd-divx.htm
    Sep 2006
    i have a Chipped Ps2 but is Messiah 2 Chip
    Profoundly deaf.
  10. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I have Crystal, but that shouldn't make any difference. Try SMS. A little crude UI IMO, but functional.
    http://sms.ps2-scene.org
    /Mats
    Sep 2006
    What u mean by above?
    Profoundly deaf.
  12. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Well, it's a little "barren" and unintuitive user interface (at least earlier versions) even to my taste, but things have improved lately.
    I guess it's not all that easy to write easytouse code when a game controller is the only interaction with the outside world available.
    There's a good tutorial on how to create discs for SMS on the site linked to above. See the "CD Image" link on the SMS site.
    /Mats
    Sep 2006
    i dunno if i followed it correct all i did was use Version 1.7 (Rev 4) 'PAL' burned to CD now how do i get it to memory card
    Profoundly deaf.
  14. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    To put it on a mem card, you need some file manager, like uLaunchElf. I find it most convenient is to put SMS on all discs (it's small! - 442 kB) that contain the files you want playable on the PS2, and rename SMS.ELF to BOOT.ELF (while keeping system.cnf as the instructions on the SMS CD Image "how-to" page). That way, when you put the disc in the PS2, SMS will boot, and be ready for action.
    A Pc or standalone DVD player will treat the CD as any other data CD.
    /Mats
