Hello. I tried using this free tool iRiverter that is supposed to convert video to my iRiver. Unfortunately, it does not convert video recordeed from my Canon ZR 700. So I found a couple tutorials online that say I can use Virtualdub to do it as well. I thought I would give it a shot. Unfortunately, when I try to open any of my .mpgs that were captured from my camcorder (I used the Hauppuage WinTV PVR 250 to capture my video to MPG form), I get this error:
MPEG Import Filter: invalid pack at position 3: marker bit not set; possibly MPEG-2 stream
Can anyone help me with this? Thanks!
It appears iriverter uses mencoder. You could try SUPER as it can also use that program for conversions. If you wanted to use VirtualDub, why not just input to the computer with FireWire from the camera? If you add a DV codec like the Panasonic DV codec, VD will accept the file. I use WinDV for the DV transfers. Or if you need to use MPEG, then VirtualDub Mod or VirtualDub-MP2 can accept MPEGs.
What format does the iriver device need?
Xvid on Iriver X20 - Flickering
By kidcash in forum Portable VideoReplies: 2Last Post: 8th Jan 2008, 04:43 -
Which software to convert video for iriver Clix2?
By ShaqArif in forum LinuxReplies: 1Last Post: 20th Aug 2007, 14:53 -
sorry for the offtopic! need an advise on iRiver iHP-100-THE HD IS DEAD!!!
By lubegiant in forum AudioReplies: 1Last Post: 1st Aug 2007, 11:12 -
iRiver H120 - Does it REALLY support WMA, if so how do I update the DB?
By amdk62 in forum Newbie / General discussionsReplies: 1Last Post: 11th Jul 2007, 17:56 -
Any IRiver PMC 120 Hack ?
By StoneColdWhat in forum Portable VideoReplies: 0Last Post: 20th Jun 2007, 15:53
