I have some movies converted to mpg4 and I wanted to write them on a single dvd. Individual movie plays on my dvd player if only one movie is written. But if I write all movies then I get a message that the disk can not be played.
Spacewise all the movies are well within the capacity of a dvd5 disk.
I used nero and burnt the dvd as data dvd.
What can be the solution and what should be the correct codecs that I should use. ( my dvd player supports mpeg4/ divx/divx ultra/ divx pro
My player is Pioneer 696 whiich supports mpg4 and divx both.
The disk I used was Samsung make DVD+RW
One movie was already burnt on this disc and was playing fine on my player. I then added 2 more movies to the same disk in mpg4 format and burnt as data dvd in multisession format
After that the first movie which was playing fine also stoped to play
Did I do something wrong? -
well, thanks friend
I will give it atry and come back
But is it ok that I use data dvd option for burning using nero? -
yes use data dvd as your burning method .... burn all the movies at the same time (in a single session) and finalise the disk ... it should then work fine
Is there a guide to merging multiple DVD titles into a single output file?
By Lolipop Jones in forum DVD RippingReplies: 10Last Post: 11th Nov 2016, 20:19 -
Multiple AVIs to a single SD-DVD with MultiAVCHD
By jeffdb27 in forum Authoring (DVD)Replies: 3Last Post: 1st Jun 2012, 16:17 -
choice: burn to single BD, or multiple movies in 264?
By jlm86 in forum Blu-ray RippingReplies: 15Last Post: 20th Feb 2011, 21:14 -
Multiple Titles In A DVD ISO To A Single AVI
By Simmons in forum Video ConversionReplies: 1Last Post: 9th Aug 2010, 01:32 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 12:15
