In Cyberlink Power dvd the movie is cut off. It is cut off from all sides. I have tried different settings. I had power dvd 5, it installed 6 and then pro and it still cuts off the video. Any ideas ? Thanks
Please explain what you mean by "cut off". Compared to what? Which display?
Hi, If you are having the same thing i had once,
try going to full screen, then minimize, then full screen again. -
Kschang, The whole picture doesn't show. It is also happening in windows media player.
Alprepress, tried it and it didnt work
maybe it is something with windows xp.
thanks -
Does this happen with ANY DVD (not just store bought, but home-made ones too)?
Does this happen with AVI files, or just DVDs? -
It happens with any DVD. Store bought, homemade. I took one of the same dvds to work to try it. It works at work. I noticed when I played it in windows media player the ffdshow codec icon was in the lower right hand toolbar. I had installed ffdshow once on my PC and then removed it, and now I am wondering if I install it again when I get home if it will correct the problem.
Also avi files that I make through Vegas Movie Studiio won't play anymore in windows media player.
I dont know if other avi files work. I will try when I get home. -
still no luck.
All other formats work properly. Seems to just happen playing DVD's
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 04:46 -
Need to cut out 5 minutes of video from a dvd
By darkcyber in forum EditingReplies: 5Last Post: 2nd Nov 2010, 19:10 -
How to cut out the text on a dvd video
By tealmarlin in forum EditingReplies: 1Last Post: 9th Nov 2009, 13:27 -
DVD output video is cut off on left and right
By Grunberg in forum Authoring (DVD)Replies: 6Last Post: 10th Nov 2007, 19:18 -
Video cut on sides of TV of Burned DVD
By theguy1991 in forum Authoring (DVD)Replies: 6Last Post: 29th Jun 2007, 19:24
