    Oct 2006
    South Yorkshire.
    hi, i have recently wiped my hard drive, and i have been re-installing win xp and other programs. i have just installed .net 1.1 .net2 and svcd2dvd 2.1 svcd2dvd used to work fine, but after installing it again, on startup i get a box with "unspecied error" . i have tried re-installing .net ans svcd2dvd but with no sucess. i have the option of " Details, Continue and Quit" this is some of the text the Details ( the relevant part i hope ) but if not i can post all of it.
    ************** Exception Text **************
    System.Runtime.InteropServices.COMException (0x80004005): Unspecified error
    at QuartzTypeLib.FilgraphManagerClass.RenderFile(Stri ng strFilename)
    at x3284ccece41ee22b.x79ed6fa5f8db6479.x535825f93c028 407(String xa39af5a82860a9a3)
    at x3284ccece41ee22b.x210ff09a2516b1a7.x92b839eef7ea4 c46(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
    Has anyone any ideas how i can solve this problem ? Thanks.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok. Can you try to open the splash.mpg file in the S2S folder in WMP? Can you play it?
    Oct 2006
    South Yorkshire.
    Slash.mpg will not play in WMP. So i have just upgraded WMP to v10 and it still does not play.
    WMP say unknown error and displays a code
    Error ID = 0xC00D11CD, Condition ID = 0x00000000
    Oct 2006
    South Yorkshire.
    Hi, Just a note to say thanks for the help. It was a problem with WMP and mpg`s. Got that sorted and now svcd2dvd works great.
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Cool. What did you do to sort it?
    Oct 2006
    South Yorkshire.
    well, after spending 3 to 4 hrs trying various things, remove / installing directx, various codecs, wmp 10, 11, 9. Searching around the net and trying diferent solutions to play mpg`s on wmp. I decided that if wmp and mpg`s were causing this problem, what others might occur in the future.I decided it would be easier and quicker to format my drive and reinstall winxp. So thats what i`ve done, wmp plays mpg`s now, svcd2dvd works a treat again, and i have the majority of my programs back on my drive
    Thanks for pointing me in the right direction.
    ps. other programs i had on my pc also would not play mpg`s ( bsplayer for one ).
