    Apr 2005
    How to convert vob-files (in a VIDEO_TS-file) to an avi-file, keeping the subtitles and everything else? I have heard of the program X"ilisoft DVD Ripper" but it is only available in a trial verision (for 5 minutes ripping).
    Apr 2005
    Thanks. But is it possible to use severeral vob-files as input-files and create one avi-file out of these several vob-files?
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You should be able to load the IFO file into AutoGK, and this will automatically load the VOB files it needs in turn.
    If in doubt, Google it.
    Apr 2005
    But there are two IFO-files in the VIDEO_TS-file containg the vob-files.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    So try loading the VTS_01_0.IFO file
