well damn
This site isn't about game copying.
Better luck at GameCopyWorld or similar sites.
Moving this thread to Off topic.
/Mats -
you probably need a swap magic patch for the game look at the officail swap magic website and see what they have
start here
http://swapmagicfix.com/
Just start up swap magic swap in zoneloader boot then swap in scarface and boot.
You have to but zoneloader on your memory card to do this you might be able to the opposite also to get it to work without having it on your memory card but the first method should work fine if you can get it on your memory card
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 10:53 -
Problem to swap one subtitles to another
By mangus37 in forum SubtitleReplies: 7Last Post: 2nd May 2010, 04:52 -
Swap files, LiveCDs
By Ai Haibara in forum LinuxReplies: 2Last Post: 23rd Jun 2009, 22:50 -
Swap out video without changing anything else on a DVD-R?
By bizzybody in forum Authoring (DVD)Replies: 16Last Post: 24th Dec 2008, 05:07 -
Most convinient way to swap a HDD?
By videohalp in forum ComputerReplies: 3Last Post: 27th Jun 2008, 18:24
