    Jan 2003
    Milwaukee
    I like to create this dvd menu, but have no knownledge of how to do it. Can someone help me how to make this menu. Use any program, I don't care. I just need a tutorial and will buy the program as soon as I know what program can make this type of dvd menu.
    The image doesn't work, it says image hosted by angelfire. You can post the image in the forum if you click on the "post reply"-button and add the file under Upload file.
    Jan 2003
    Milwaukee
    here
  4. Member PTsniper's Avatar
    Aug 2006
    Portugal
    I think you can try DVD Lab Pro or DVD Lab, it's a terrific program, and you can use it for free during 30 days (thats what I'm doing)
    If you want something a little more simple, without scene selection or without subtitles, etc, tou can use TMpgenc DVD Author 2.
    So good luck.
    BTW, if you try any of this programs, read some guides, they really helped me.
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    TDA can do chapter menus if that's what you mean by "scene selection", one of the better newbie friendly authoring programs (imho).
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Encode your "preview" covered with a layer on top in "background" color (masking top left and lower right corner). The rest is simple.
    /Mats
    Jan 2003
    Milwaukee
    I kind of looking into the design of how it look and where things are placed. Nothing about the chapter...
  8. It's even possible with GfD. The only additional program needed is any kind of 'paint' (windows paint will do) to draw the mask.
