My LiteOn SHM-165P internal DVD burner drive makes a rumbling noise when burning disks. Especially noticeable near the end of the job, and the rumble cycles up and down in volume about every 2 seconds.
But so far (after about 3 months and 30 or so disks burned) zero coasters.
The vibration alone is worrying for the effect it may have on the other components.
Is disaster imminent?
Comments, advice?
You are most likely hearing the disc speed increase as it reaches the outer parts of the disc. Some drives make more noise than others. Either way, it is normal.
Google is your Friend -
Have you tried tightening the screws in the drive bay? Sometimes the vibrating is simply a result of the DVD drive being slightly too loose in the tower.
or having all the screws screwed into the drive.
I'm guilty of sticking one or two screws in a drive and leaving it that way. -
You can also get rubber mounts for the screws.
Buying a New BR Burner
By golfnut in forum DVD & Blu-ray PlayersReplies: 22Last Post: 11th Apr 2012, 10:36 -
Hi8 to PC, video vibrating (Video comparisons)
By smashwings in forum Capturing and VCRReplies: 6Last Post: 3rd Apr 2012, 11:00 -
How do you know when you have a bad burner?
By will7370 in forum Newbie / General discussionsReplies: 5Last Post: 18th Feb 2012, 12:14 -
Is it time to get a BR burner?
By beavereater in forum ComputerReplies: 10Last Post: 8th Nov 2011, 00:37 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15
