I guess the solution is quite simple, but I don't get it.
I have to Video_TS directories created with IfoEdit.
What I want is that the one movie (Video_ts1) is track1 on the DVD and the other one (Video_ts2) is track2.
How can I put them together?
My guess would be to use "merge program tables". But that means that I have to change in Video_ts2 first that it is track2 and not track1. But I cannot find it.
Sure but the mentioned things there don't help in my case...Originally Posted by kschang
Like I said, I guess in my case it is just that I have to change one value in the second Video_ts.ifo and then the merge should do it, but I cannot find this value... -
(1) Like I said, this topic does not help much in my case since it tries to do something different.Originally Posted by mats.hogberg
(2) DVDFab did the job.
(3) But still I would like to know how to manipulate the video_ts.ifo to achieve the same by hand.
Thanks anyways.
I don't see the point with reinventing the wheel - the sticky covers most bases for merging 2 DVDs (which is what you have) to one.
Glad you solved it, tho.
/Mats
How do I edit, cut, join DVDs, VOB, VIDEO_TS folders
By Baldrick in forum Authoring (DVD)Replies: 13Last Post: 9th Oct 2013, 07:03 -
Video Files, join video_ts and flash video
By Pumkinhead in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2011, 07:45 -
VIDEO_TS 7GB to VIDEO_TS 4GB
By klemyz in forum ffmpegX general discussionReplies: 2Last Post: 9th Dec 2009, 13:43 -
how to join 2 video_TS
By hilario in forum EditingReplies: 2Last Post: 6th Oct 2009, 17:33 -
DVDfab rips out many video_ts, how do i join them together
By Cococokie in forum DVD RippingReplies: 1Last Post: 28th Dec 2007, 06:40
