I have recorded some programmes from the Tv using my dvd recorder
using the ESP rec mode 3.00 hours. It as also recorded some adverts.
I have tried using DVD Shrink and VideoReDo Plus, to execute adverts, but
no luck, i get the following when using Shrink, Invalid DVD navigation structure,
and when using VideoReDo Plus it states, output stream error: Error opening file
Is there another programme i could try.
Thanks for your time.
Check that recorder was set in dvd-video mode and not vr mode .
If disc is in vr mode , copy the files from disc to pc , and use tmpgenc to open and convert them .
If video mode was used ... media error possible ... use brand like verbatim .
Also beware , of the media type required by the recorder ... this can cause similar problems . -
NO! adverts are a contract that you implicitly have when you watch a programme on commercial TV. By not watching the adverts you are breaking that contract and liable for incarceration in Guantanamo Bay.
Shrink is not a great way to get rid of adverts try dvd author, far better and it can read most dvd recorder discs (dvd-vr mode?)Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Alternative to VideoRedo for Editing MPEG2 Files?
By christopheramos in forum EditingReplies: 34Last Post: 20th Jan 2015, 14:09 -
Help with transcoding mpeg-2 files after using VideoReDo...
By photodent in forum Authoring (Blu-ray)Replies: 3Last Post: 22nd Mar 2010, 19:18 -
Any tools like VideoRedo for editing h.264 .tp files?
By cwy in forum EditingReplies: 2Last Post: 11th Sep 2009, 10:40 -
Alternative To VideoReDo But Still As Fast (Cutting WMV Files)
By Teac23 in forum EditingReplies: 3Last Post: 29th Nov 2008, 14:05 -
Error when trying to shrink DVD files
By bambam in forum DVD RippingReplies: 10Last Post: 9th Jul 2007, 11:54
