I'll try to be quick!
I have a divx (.avi) that i want to convert to DVD (.vob).
avi is 23.976 fps --- its subtitles work great with media player + vobsub.
i convert to PAL (25fps checked) with CinemaCraft. I get the .mpv file which must be 25fps.
I author with Dvd-Lab. Add the subtitles as they are. Burn with Nero. Play on tv and subs are out or sync.
is that because I converted from 23.976 to 25fps?
Results 1 to 9 of 9
Yes, you lost sync when you speed up your video by changing its framerate from 23.976 to 25fps.
The only thing you have to do:
Use Urusoft's SubtitleWorkShop to convert subtitles from 23.976 to 25fps too.
It's easy and quick.
Good luck. -
You sure its gonna work?
Are these settings correct for Subtitle Workshop?
Input FPS: 23,976
FPS: 25 -
Hi!
I'm quite sure it will work.
Your settings are correct (Input FPS = 23.976 and FPS = 25).
If you notice, when you do this, timestamps will be reduced. At 25 minutes, it will be almost 24 minutes (23.976 minutes).
Why won't you test before burn? -
how can I test?
my files are .mpv (video) .mpa (audio) and .srt (subtitles).
Is there any proggy that can test subtitles on mpv video? -
vlc or media player classic should be able to test them
Read my blog here.
Media Player Classic he said. Not Media Player or Windows Media Player. It opens mine just fine.
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
Problem with subtitles in videos of 23.976 fps
By sgbd in forum Authoring (DVD)Replies: 5Last Post: 7th Nov 2010, 18:56 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 04:53 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
