Results 1 to 9 of 9
  1. ok here is the background for this clip
    i recorded this from free to air tv onto a vhs tape when we first moved into this house before i had a chance to fix the antenna on the roof. the reception was a bit snowy and kinda nasty all round.
    i ran it from the vcr through one of those video enhancer devices that strips off some of the timing signal and replaces it as well as giving a small amplification of the signal.
    the capture was done at 352x576 in mjpeg and frameserved to tmpgenc using virtualdub. i used the following filters
    virtualdub -> blend deinterlace, bilinear resize to 352x288
    tmpgenc -> defaultlevel noise removal
    the following is a short clip, around 15 seconds and 2.6 megs
    home.iprimus.com.au/zebu/sample1.mpg
    all comments and suggestions are appreciated
  2. Member vhelp's Avatar
    Mar 2001
    New York
    Hello Zebu,
    My comments for you sample clip is:
    * it was ok-to-good quality for an off-the-air capture (well, it was my first taste
    of someones else's OTA*** capture clip) - not a DVD source, but still ok.
    * so far, w/ the default noise removal, it looked pretty good for starters.
    ...how long did you spend on it to get it to this point for sharing, he he....
    *** I may not be the best judge for OTA capture and encode, and maybe others
    here have and might have a difference in opinion from mine, which is ok w/ me.
    curious to see (read) what others w/ OTA experience will have to say.
    Oh, can't think of the name of the band, but I like them!!
    Keep up the good work.
    -vhelp
  3. the band is "the corrs"
    the cap wasnt strictly off the air, but off the air to vhs then to the pc
    also in case anyone was wondering i used a pinnacle pctv rave for the recording
  4. Member vhelp's Avatar
    Mar 2001
    New York
    Opps!!
    I made a mistake in my comment...
    I left out that I didn't view on TV. Sorry bout that!
    I only saw via PC. I have a couple of VCD clips I'm
    finishing up on and will add your's to my burn shortly.
    Then, I'll let you know what my comments are.
    -vhelp
  5. Member vhelp's Avatar
    Mar 2001
    New York
    Yep, looks fine'ta me, though I didn't burn to PAL - didn't realize
    that it was. But it worked with my other NTSC burns.
    -vhelp
  6. it looks pretty decent,
    for a minute there I thought the post topic said "tell me what you think of this crap" hehe
    <font size=-1>[ This Message was edited by: geniv on 2002-01-12 19:44:31 ]</font>
  7. Zebu, whats your system specs, and recording specs too.
    How much does the Pinnacle PCTV cost in AU$ ..?
    Thanks.
  8. system specs:
    Duron 850 @ 1054
    ECS k7s5a motherboard
    192 megs ram
    windows XP pro (using fat32 file system for other reasons)
    20gig western digital 5400rpm hard disk
    sb live value
    and of course the pctv rave.
    the capture details are pretty much what i said before except i had the picvideo Mjpeg codec set down to 18 because i was short on space, at that resolution and quality it was taking up about 3.5 gigs an hour and my cpu was at about 50% utilisation while it was doing it using iuvcr and the hacked wdm drivers that are also on that page.
    the pctv rave cost me about $130 in a pre GST sale at harvey norman a while back but you can get one from cougar computers in canberra for about $180 www.cougar.com.au/index.cfm?ID=33&PART=4546
    i hope that helps cybermage26
  9. thanks , Im proud of you, hehe. it looks good.
    I only got a Pentium 3 - 450 (256mb SDRAM, 5400 - 40gigHDD) and hoping of doing some decent capturing to VCD also, any pointers on codecs or shit to use? Resolution etc?
