Hi guys I have sky+ and I was just wondering what I would need to capture some of my fav series' and other programs on to my laptop.
Like I said I have sky+ and I have a laptop. What else do I need guys? Also is there a guide anywhere showing me how to capture pdtv?
You need a capture or TV card. You then feed the output of your Sky+ receiver box into the card.
Google is your Friend -
Laptops are not the most suitable equipment for real time TV capture, you are going to need a USB capture box.
You also need to tune your receiver to the desired channel, this is due to the fact that you will not be able to instruct the USB to do this operation.No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. .. -
You could try the following device:
http://www.provantage.com/diamond-pvr660rcusb~7DIAM274.htmNo tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. .. -
Because he has a laptop, that rules out the Skystar 2.Originally Posted by SatStormNo tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
there are USB versions of Sky Star 2
http://www.technisat.com/?site=produkte/produkteview.php&kid=29,100&pid=1190&reload
www.satelliteguys.us/archive/index.php/t-13864.htmlLa Linea by Osvaldo Cavandoli
capturing from sky+ box to pc
By supercoop in forum Capturing and VCRReplies: 1Last Post: 7th Jan 2012, 21:11 -
Problem capturing sky digibox recordings
By scamperoo in forum Capturing and VCRReplies: 9Last Post: 19th Oct 2009, 10:32 -
Capturing Dolby Digital via SPDIF?
By W_Eagle in forum Capturing and VCRReplies: 3Last Post: 11th Jul 2008, 13:15 -
8mm to Digital - Capturing w/ DV Camcorder
By tripecac in forum Capturing and VCRReplies: 61Last Post: 9th Jul 2008, 19:51 -
Sky + And/Or Sky HD Recording To Pc With DAZZLE
By akenny01 in forum Capturing and VCRReplies: 0Last Post: 7th Mar 2008, 19:02
