i have nero dvd software and cannot get it to use my dvd player. i just built this pc and took the dvd rom and dvd burner out of other pc but just purchased the burner about a week ago.
i know the dvd burner works
i put it in another computer and it worked
it will play dvd's and cd's
it will burn cd's using my old cd software
dvd-rom-master
dvd-rw-slave
when in nero i select the drive i want to use but it only allows me to select my dvd-rom drive which dosent burn dvd's and it trys to burn but can't
how can i fix this?
well thanks for help![]()
Which version of Nero, and what is your DVD burner? If you're using Nero 5, 6 or 7, check Ahead's site to make sure whether or not you're using the latest versions. Depending on how recent/new your burner is, however, you may have to upgrade to Nero 6 or 7 to get Nero to recognize it.
Edit: Can you access the drive normally everywhere except Nero?If cameras add ten pounds, why would people want to eat them? -
Run Nero Infotool see if it shows up. You may have to set the burner to master and the dvd-rom to slave.
Nero Won't see my DVD Burner !!! HEP ME HEP ME!!!
By THE_oldguy in forum DVD & Blu-ray WritersReplies: 14Last Post: 24th Dec 2009, 12:07 -
Burner Won't Recognize Blank DVD-R Discs
By ddowden1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Aug 2009, 07:52 -
Dvd Burner only reads older dvds, won't read newer ones all the sudden??
By kpaxfaq in forum DVD & Blu-ray WritersReplies: 6Last Post: 28th Feb 2008, 15:11 -
External Comstar DVD/CD Burner won't boot up but fan still turns on
By smiles in forum DVD & Blu-ray WritersReplies: 11Last Post: 3rd Oct 2007, 10:05 -
DVD burner won't finish burn
By JDShaffer in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Jul 2007, 21:41
