I HAVE A JVC DVD PLAYER. IT STATES IT CAN PLAY DVD, VCD, AND CD'S. BUT IT DOES NOT SAY CD-R/RW. THEREFORE IT WILL NOT PLAY MY BURNED VCD MOVIES. IS THERE ANY WAY TO MAKE A ORIGINAL OR STAMPED VCD?
er .... simple answer - no .....
.... unless you wanna spend a few hundred dollars/pounds/euros etc getting your 'burnt' VCD glass mastered!
Have you actually tried sticking a CDR in it? The manual maybe be telling porkies!
Sue xxx. -
If you experiment with different brands of CD-R, you will often find one that works. CD-RW usually works better in these cases too.
Regards.
Michael Tam
w: Morsels of Evidence -
i have a jvc and it says the same thing plays dvd, vcd ,cd.
i use memorex cd-r and they work great. -
I use silver BASF ( now emtec ) 80 min I think these are the best for the price. Stick to a standard template video@1150 kbits/sec and audio@224bits/sec. then try it...
Hi Jakobie,
my JVC XV-522 plays VCD´s burned with Nero 5.5 on german brands like LIFETEC or TEVION (thge cheap one from ALDI). I think it´s not a question of the CD-R brand it´s more a question of the burning application. For example vcd´s burned with a software from Roxio, i belive it´s WINONCD doesn´t work in my JVC.
The JVC also canNOT play SVCD, but it can play XVCD´s with a datarate up to 2500kbit/s!!! So you can get a perfect quality movie on two CD´s
Trying to make a time-lapse video (speeding up original footage): How?
By maskingtape in forum EditingReplies: 30Last Post: 16th Jul 2010, 00:39 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 05:50 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 08:35
