I have an avi file [xvid mpg 4] thats out of sync when played back on WMP or VLC. It starts off in sync but increasingly goes out as I skip through the movie. It's 0x2000 AC3 Dolby/ 48000Hz 192kb/s total [2 chnls] according to GSpot.
I'm looking to burn it and play it on my Philips 642 so I need to know if and how this can be fixed....RpM
First, forget WMP, it lies.
Play the file in VirtualDub. You will need to install the AC3 ACM Decompressor first because of the AC-3 audio.
I would probably burn the file with an RW disk and test it before I got too involved trying to fix it. It might play fine.
Good luck. -
Thanks Scorpion King for the input...I installed the codec that you mentioned and played it with VirtualDub...still the same problem. I also burned it just to give it a try...no good. Is there a next step
oh boy....
I just wrote a full page of stuff but I think the best thing for you to do first is:
Heres the guide for gradual loss of sync. Try this first.
https://www.videohelp.com/forum/userguides/140540.php
If that isn't whats wrong with it then come back. We'll try something else. ok
Good luck.
[edit]Only don't use the Tmpgenc thing as in the guide, just save as WAV then use AVIMux GUI or VirtualDubMod and mux the new audio with the video. Test play that again in VD. If you have trouble with the mux part we'll work on that next.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
AutoGK, Audio Sync problem.
By steve_hawthorn in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2009, 00:39 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
![Computer details: WinXp SP2
2.8ghz [PowerLeaped]
Maxtor 2-100gb Sata
2048mb RDRAM
Geforce 6800 Ultra 256mb 8XAGP
TwinHanDTV
Philips 642
Mad Dog 16XDVD9
Lite-On LTN483S 48X
Dell Pentium 4 478/Northwood
SoundBlaster Audigy 2 ZS Comp](/images/buttons/computer.gif)
