    Dec 2005
    I am trying to convert some camcorder footage (sent to me on DVD) to an AVI so that I can edit it. I have ripped the VOBs (DVD decrypter) and used GDIndex (dgmpgdec) to create a .d2v file. I then use a .avs script to get VirtualDub to output an avi file. However, when I pass in the .avs script to VitualDub I get an error :-
    Avisynth open failure:
    AVIFileSource: couldn't open file xxx.wav
    I have checked the obvious (the wav file is present !) - I created it from GDIndex.
    I have followed the same process with other footage and it has worked before. I wanted to use the ac3 audio file which was generated byGDIndex; but I cannot find the ac3 plugin for Avisynth.
  2. Check the path to the wave file in your avs script. It's better to provide a full path to the file even if the avs is in the same dir as the d2v and wave file
    Dec 2005
    It already has the full UNC path.
  4. So don't put the audio in the AviSynth script. Process it separately, and remux when the encoding is done.
    Were you looking for the AC3Source.dll?
    http://ziquash.chez-alice.fr/
    Dec 2005
    Many thanks - That was the dll I was looking for. I will give it a try
