I am trying to use SVCD2DVD to create playable DVDs from HD content. I have used VideoRedo Plus to extract .mpg files from the transport streams. These .mpg files are 1280x720.
I load these into SVCD2DVD and set it going and it creates an S2D file (size 1280x720) and VOB files (size 1280x720). Consequently, the DVD doesn't play !
I am using 2 pass encoding and pulldown, with keep AC3.
Am I misunderstanding what SVCD2DVD actually does ? I thought it would convert the files to 480 pixels ...
Anthony
It will not convert the .mpg files, if you want it converted to 720x480, you should use the TS files as your source (assets).
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
What is a Reasonable Size for a DVD File Converted to AVI or MP4?
By Novice20 in forum Video ConversionReplies: 3Last Post: 23rd Oct 2011, 21:58 -
Converted videos display issues
By thumpy in forum Video ConversionReplies: 6Last Post: 20th Apr 2010, 13:40 -
DVD wideScreen to DV - keep display size
By DavidCasillas in forum DVD RippingReplies: 1Last Post: 24th Jan 2010, 10:14 -
what display size should I use in TV card settings
By jimdagys in forum Capturing and VCRReplies: 1Last Post: 8th Apr 2008, 20:51 -
DVD display size issue
By tanshul22 in forum Software PlayingReplies: 1Last Post: 28th Nov 2007, 19:13
