Hi,
This is my first time here and I'm hoping someone can help.
I have been editing 1 hour long footy vides in premier 6.0 and burning with "Sonic MyDVD". I have turned oput some very watchable stuff on obout 40 DVDs over the last three years. I have always exported from premier as a movie iusing DV AVI format (it may have been the default when I started ,it worked,so I left it) and now I have reason to look a little harder the movie file in is a nero Mediaplayer media file?(No matter it works fine also). I now have a video of a seminar that is approx 2hrs.10 min. A movie of 27 GB.
Question; Can I fit it on one DVD?
If the answer is yes :
Do I need to change the out put from premier?
Do I need to down load a compression program?(I have DVD srink but it looks to me can't be used the way I need)
Maybe I have just missed somthing very basic.
While trying to find answers I find in export from premier all my frames are key frames and the buttons to change this remain grey?
Results 1 to 1 of 1
Can't edit video file converted from DVD to AVI in Adobe Premier
By GalMed in forum EditingReplies: 12Last Post: 24th Feb 2012, 14:53 -
Editing a DVD video in Premier
By smallears in forum MacReplies: 8Last Post: 9th Aug 2009, 13:55 -
Adobe Premier Pro to dvd
By tat2loo in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2008, 13:57 -
M2TS to Premier
By Mylriahd in forum Video ConversionReplies: 24Last Post: 6th Mar 2008, 11:17 -
Premier Elements help
By didikai in forum Newbie / General discussionsReplies: 7Last Post: 27th Aug 2007, 03:54
