hi,
i have had 3 coasters continuously. the same media used to work earlier.
its a local DVR-R. i have used it earlier of the same batch. but now i have no idea whts happening. Nero's info tool says its a FUJIFILM DVD-R.
below are the 3 logs from nero .... plz someone help me figure out whats wrong.... i'm not very keen on firmware flashing unless i'm sure it will solve my problem.
all the time the problem has been at the end when lead-in & lead-out are written... in case any other info is required plz let me know...
i need help real bad... & thanks for even readying this...
_____________________
LOG1
1C80-0000-19E5-MA2X-4003-4074-****
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero Version: 7.2.7.0
Internal Version: 7, 2, 7, 0
Recorder: <SONY DVD RW DW-D22A> Version: BYS2 - HA 1 TA 1 - 7.2.7.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <VR0315B MBE331S >Version: 2.0B - HA 1 TA 2 - 7.2.7.0
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : ST380011A atapi Port 0 ID 0 DMA: Off
CdRomPeripheral : SAMSUNG CD-ROM SH-152A atapi Port 0 ID 1 DMA: Off
CdRomPeripheral : SONY DVD RW DW-D22A atapi Port 3 ID 0 DMA: On
CdRomPeripheral : VR0315B MBE331S 2.0B vaxscsi Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
SAMSUNG CD-ROM SH-152A H: CDRom0
SONY DVD RW DW-D22A I: CDRom1
VR0315B MBE331S J: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 750MB (768748kB)
Free physical memory: 225MB (230408kB)
Memory in use : 70 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.9.2006
ISO compilation
6:02:13 PM #1 Text 0 File Isodoc.cpp, Line 6440
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
6:02:13 PM #2 Text 0 File ThreadedTransfer.cpp, Line 540
ReadBuffer-Pipe got 262144KB of Memory
6:02:13 PM #3 Text 0 File Reader.cpp, Line 124
Reader running
6:02:13 PM #4 Text 0 File Writer.cpp, Line 113
Writer I: SONY DVD RW DW-D22A running
6:02:13 PM #5 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
6:02:13 PM #6 Text 0 File Burncd.cpp, Line 3405
Turn on Disc-At-Once, using DVD media
6:02:13 PM #7 Text 0 File DlgWaitCD.cpp, Line 298
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2219375 (493:11.50, 4334MB)
6:02:13 PM #8 Text 0 File DlgWaitCD.cpp, Line 310
Write in overburning mode: NO (enabled: CD DVD)
6:02:13 PM #9 Text 0 File DlgWaitCD.cpp, Line 2842
Recorder: SONY DVD RW DW-D22A, Media type: DVD-R
Disc Manufacturer: FUJIFI - LM03
Disc Application Code: 64, Disc Physical Code: 193
6:02:13 PM #10 Text 0 File DlgWaitCD.cpp, Line 482
>>> Protocol of DlgWaitCD activities: <<<
6:02:13 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 848
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2219376 (2219376) = #2219376/493:11.51
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2219376 blocks [I: SONY DVD RW DW-D22A]
6:02:13 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1063
Prepare recorder [I: SONY DVD RW DW-D22A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4545282048, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 2219376 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2219376 | 0 | 0x00
2219376 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
6:02:13 PM #13 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
6:02:13 PM #14 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
6:02:13 PM #15 Text 0 File Burncd.cpp, Line 4236
Cache writing successful.
6:02:13 PM #16 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
6:02:13 PM #17 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 8x (11,080 KB/s)
6:02:13 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2722
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
6:02:14 PM #19 Text 0 File DVDR.cpp, Line 2965
Recording mode: Sequential Recording Mode
6:02:14 PM #20 Text 0 File DVDR.cpp, Line 3121
Start write address at LBA 0
DVD high compatibility mode: Yes
6:02:14 PM #21 Text 0 File Cdrdrv.cpp, Line 9096
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
6:04:36 PM #22 Text 0 File Cdrdrv.cpp, Line 1230
18:04:36.828 - I: SONY DVD RW DW-D22A : Queue again later
6:41:38 PM #23 SPTI -1135 File SCSIPassThrough.cpp, Line 291
I: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5C 00 00 00 00 00 00 00 0C 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x034dd800: Len xc
6:41:38 PM #24 SPTI -1023 File SCSIPassThrough.cpp, Line 291
I: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1023)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 1D 72 00 00 00 20 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 2C
Buffer x05af0000: Len x10000
0x48 C8 06 61 A3 CE 8D 46 BA CA 15 21 04 D9 C2 15
0x41 8A 16 45 EE 76 5E 56 99 4A 68 A0 6A 32 EA 6D
0x26 D4 8E 2E 12 84 89 97 5D 56 D8 79 83 D9 51 D5
6:41:38 PM #25 CDR -1023 File Writer.cpp, Line 302
Command sequence error
6:41:38 PM #26 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
6:41:39 PM #27 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
6:41:39 PM #28 Text 0 File DVDR.cpp, Line 3337
EndDAO: Last written address was 1929727
6:41:39 PM #29 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 8x (11,080 KB/s)
Existing drivers:
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 8/3/2004 10:59:42 PM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
LOG2
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Free physical memory: 374MB (383036kB)
Memory in use : 50 %
Use Inquiry : 1
7.10.2006
ISO compilation
5:51:59 PM #1 Text 0 File Isodoc.cpp, Line 6440
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
5:51:59 PM #2 Text 0 File ThreadedTransfer.cpp, Line 540
5:51:59 PM #3 Text 0 File Reader.cpp, Line 124
Reader running
5:51:59 PM #4 Text 0 File Writer.cpp, Line 113
5:51:59 PM #5 ISO9660GEN -11 File Geniso.cpp, Line 3312
5:51:59 PM #6 Text 0 File Burncd.cpp, Line 3405
5:51:59 PM #7 Text 0 File DlgWaitCD.cpp, Line 298
5:51:59 PM #8 Text 0 File DlgWaitCD.cpp, Line 310
5:51:59 PM #9 Text 0 File DlgWaitCD.cpp, Line 2842
5:51:59 PM #10 Text 0 File DlgWaitCD.cpp, Line 482
5:51:59 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 848
5:52:00 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1063
DAO infos:
MCN: ""
DAO layout:
5:52:00 PM #13 Text 0 File SCSIPassThrough.cpp, Line 39
5:52:00 PM #14 Phase 24 File dlgbrnst.cpp, Line 1730
5:52:00 PM #15 Text 0 File Burncd.cpp, Line 4236
5:52:00 PM #16 Phase 25 File dlgbrnst.cpp, Line 1730
5:52:00 PM #17 Phase 36 File dlgbrnst.cpp, Line 1730
5:52:00 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2722
5:52:00 PM #19 Text 0 File DVDR.cpp, Line 2965
5:52:00 PM #20 Text 0 File DVDR.cpp, Line 3121
5:52:00 PM #21 Text 0 File Cdrdrv.cpp, Line 9096
5:54:17 PM #22 Text 0 File Cdrdrv.cpp, Line 1230
17:54:17.437 - I: SONY DVD RW DW-D22A : Queue again later
6:33:17 PM #23 SPTI -1135 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 20 F6 E0 00 00 20 00 00 00
Buffer x04c80000: Len x10000
0x10 12 A2 24 FE A9 48 52 32 49 23 8D 7E 1D 41 8C
0xA0 D1 9C A9 DF F4 A4 50 DA A7 BC 1A 4F E4 0F A0
0xB9 88 8A F6 00 A4 F8 B7 24 0D 8C 84 79 23 E0 77
6:33:17 PM #24 CDR -1135 File Writer.cpp, Line 302
Write error
6:33:17 PM #25 Text 0 File ThreadedTransfer.cpp, Line 229
6:33:19 PM #26 Text 0 File DVDR.cpp, Line 3337
EndDAO: Last written address was 2160351
6:33:20 PM #27 Phase 38 File dlgbrnst.cpp, Line 1730
Existing drivers:
Registry Keys:
LOG3
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
CdRomPeripheral : SAMSUNG CD-ROM SH-152A atapi Port 0 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Free physical memory: 413MB (422920kB)
Memory in use : 44 %
Use Inquiry : 1
14.10.2006
ISO compilation
2:00:05 PM #1 Text 0 File Isodoc.cpp, Line 6440
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
2:00:06 PM #2 Text 0 File ThreadedTransfer.cpp, Line 540
ReadBuffer-Pipe got 81920KB of Memory
2:00:06 PM #3 Text 0 File Reader.cpp, Line 124
Reader running
2:00:06 PM #4 Text 0 File Writer.cpp, Line 113
2:00:06 PM #5 ISO9660GEN -11 File Geniso.cpp, Line 3312
2:00:06 PM #6 Text 0 File Burncd.cpp, Line 3405
2:00:06 PM #7 Text 0 File DlgWaitCD.cpp, Line 298
2:00:06 PM #8 Text 0 File DlgWaitCD.cpp, Line 310
2:00:06 PM #9 Text 0 File DlgWaitCD.cpp, Line 2842
2:00:06 PM #10 Text 0 File DlgWaitCD.cpp, Line 482
2:00:06 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 848
2:00:06 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1063
DAO infos:
MCN: ""
DAO layout:
2:00:06 PM #13 Text 0 File SCSIPassThrough.cpp, Line 39
2:00:06 PM #14 Phase 24 File dlgbrnst.cpp, Line 1730
2:00:06 PM #15 Text 0 File Burncd.cpp, Line 4236
2:00:06 PM #16 Phase 25 File dlgbrnst.cpp, Line 1730
2:00:06 PM #17 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 6x (8,310 KB/s)
2:00:07 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2722
2:00:07 PM #19 Text 0 File DVDR.cpp, Line 2965
2:00:07 PM #20 Text 0 File DVDR.cpp, Line 3121
2:00:07 PM #21 Text 0 File Cdrdrv.cpp, Line 9096
2:01:30 PM #22 Text 0 File Cdrdrv.cpp, Line 1230
14:01:30.015 - I: SONY DVD RW DW-D22A : Queue again later
2:41:18 PM #23 SPTI -1135 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x0C
Sense Qual: 0x00
2:41:18 PM #24 SPTI -1023 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 1F 26 80 00 00 20 00 00 00
Buffer x04cd0000: Len x10000
0x80 00 00 01 08 12 74 30 04 C4 D4 94 01 90 03 D0
0x07 E1 A0 05 C0 50 30 00 E9 20 18 06 24 00 9C 06
0x20 67 80 DB 00 DF 92 89 A0 63 F5 06 23 BA D6 3E
2:41:18 PM #25 CDR -1023 File Writer.cpp, Line 302
2:41:18 PM #26 Text 0 File ThreadedTransfer.cpp, Line 229
2:41:19 PM #27 Text 0 File ThreadedTransfer.cpp, Line 223
2:41:19 PM #28 Text 0 File DVDR.cpp, Line 3337
EndDAO: Last written address was 2041471
2:41:19 PM #29 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 6x (8,310 KB/s)
Existing drivers:
Registry Keys:
end.[/b]
Have you tried contacting Ahead support? They should be the best at trouble shooting their product.
/Mats -
My first guess would be a bad batch of media or at least a few bad ones in a good batch. Your media appears to be Fujifilm LM03. You can look up the LM03 in the 'DVD Media' page to the left in 'Search Media Code'.
The error 'KEY_MEDIUM_ERROR' is the problem. It's sometimes caused by the writer being in PIO mode. But your DW-D22A is in DMA mode. However two of your other devices are shown in PIO mode, which is a problem and may be related to your burning problem.
Control Panel>System>Hardware>Device Manager>IDE ATA/ATAPI controllers.
From there, right click on one of the channels and choose 'Properties>Advanced Settings'. All drives should be DMA mode. The 'Current Transfer Mode' for Hard drives is usually DMA 4-6 and DVD burners DMA 2-4, DVD ROMs usually DMA 2. If you see any in PIO mode, that can slow things down.
Changing them back may be easy or complicated. First see if you can change them in that window. If not, I usually uninstall the channel the drive is on and let the OS reinstall it. This will usually take a reboot. This will not damage any files on the computer.
For common Nero errors, our friends at Digital Digest have this page:
http://forum.digital-digest.com/showthread.php?s=&threadid=45942
If none of that helps, try a different brand of media. -
Have you updated your firmware for your burner?
Life is like a pothole, you just have to learn to get around it. -
@redwudz - - 1) i did a search... but mine is a local brand... but i could make out the media is a bad one from the search...
2) i'm uynable to set the 80GB seagate to DMA mode... i'll try the reinstal a lil later..
3) will try changing the media and see..
meanwhile... any help would be grt...
@dvdguy4 - - no i havn't... not keen on flashing cause i dont know how to do it.. still scared... not ready for another drive yet..
thanks for the help... waiting for more... -
macho2000,
In all three logs, Nero says DMA is enabled, but the errors are coming up about 40 minutes into the burn. Despite what Nero is reporting, almost certainly the drive is in PIO mode. In an earlier post in this thread, redwudz provided the information you need to verify that is the case, and correct it.
Not only does PIO take a lot longer, but it is CPU intensive. It's a worst case scenario since you appear to be doing other things on the computer during the burn (the first log shows only 225 MB were available of the 750 MB of memory on your system).
Report back if there are any problems.
I see these were your first two posts here, so welcome to VideoHelp. -
I wouldn't waste my time with new media, firmware or anything until DMA is enabled on all peripherals. Remove controllers from device tree and reboot. Run Nero Infotool and see what your configuration looks like after rebooting. Make sure DMA is enabled on the BIOS screen during bootup for all devices or go into BIOS setup and check.
New BD Burner--Just Coasters--Suggestions?
By wwaag in forum DVD & Blu-ray WritersReplies: 1Last Post: 8th Dec 2010, 18:24 -
HP DVD+R coasters...
By lost123 in forum Newbie / General discussionsReplies: 10Last Post: 18th Nov 2010, 15:48 -
Verbatim Coasters
By hech54 in forum MediaReplies: 6Last Post: 25th Jun 2009, 17:16 -
Making some expensive DL coasters (Help!)
By nchd in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2009, 12:50 -
Getting coasters with Nero 7???
By dagerousdave in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2007, 19:12
