i hav file size of 288mb of wmv format. i use TMPGenc to convert it to mpeg and then fit it to vcd.with default settings.. the file reach to 1.94gb in mpeg file.why it so big but running hour just 1hr 10m ??is posibble for me to fit in 1vcd ?i can accept for lower quality
Look at the top left corner of this site for What is VCD. You must have used a non-VCD bitrate for the file to be so large. &0 minutes should fit on a single VCD. Tmpgenc may be having problems with the WMV, as some WMV files are encoded with variable framerates, which can throw some encoders right off track.
Read my blog here.
You must have done something wrong, a 70 minute VCD would fit on a 700mb cd.
He's a liar and a murderer, and I say that with all due respect. -
A VCD usually holds 80 min video, so 1.10 should fit nicely. Sure you used the VCD template in TMPGEnc? That size sounds more like what could be expected for SVCD.
/Mats -
For the benefit of others who may have a similar problem:
How?
/Mats
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 23:56 -
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 16:15
