    Oct 2006
    India
    hi there, i have two quetions
    1)
    i am using DVDSanta to convert my (S)VCD to dvd, using this link
    http://www.dvd-guides.com/content/view/31/59/
    i followed all instructions however the dvd is recorded but does not play on my dvd player(LG).
    2) how can i add, more movies to my alredy created movies folder(DVD format), using DVDSanta, or any other tool(may be free one)
    Regards,
    Thanks.
    Gurpreet S. Gill
    Gurpreet S. Gill
    Notion:Give a man a fish, and he'll eat for a day. Teach him to fish, and he'll eat for life.
    Apr 2004
    Miskatonic U
    DVD Santa is not great software.
    If you don't need menus, DVD Shrink in reauthor mode can bring together parts from different discs.
    If you do want menus, Tmpgenc DVD author and it's Add Video function might suit you.
    Both of these require DVD compliant output to start with. SVCD is not VD compliant.
    DVD Lab will allow you to create an out of spec DVD using SVCD source without re-encoding, however it may not play on all players because it isn't strictly a DVD.
    Read my blog here.
    Oct 2006
    India
    guns1inger thanks, for quick reply & suggestion.
    but rather it become confusing for me(which to user or not).
    Could you please tell me the procedure, tool, guide for at least 99% success of conversion.
    Regards,
    Thanks.
    Gurpreet S. Gill
    Apr 2004
    Miskatonic U
    If you want simple, ConvertXtoDVD.
    If you want quality then you need to start reading guides on avisynth, encoding, and authoring. I believe the following is a good starting point
    Video : FitCD -> Avisynth -> ProCoder Express - mpeg2
    Audio : Virtualdubmod -> wav -> ffmpgegui -> ac3
    Author : DVD lab Pro is my choice, but GUIforDVDAuthor will do what you need.
    Read my blog here.
