I am converting all of my old VHSC camcorder tapes to DVD before they start degrading too much. The are (of course) of my kids, currently 7 and 2. I am capturing them through an AIW directly to DVD compliant MPEG using Lordsmurf's guide (Thanks, BTW). I would like to use reasonably capable authoring software to make the DVDs.
My requirements are quite specific. I will be putting 4 x 30 min tapes on each DVD. The menu structure is subject to change, but right now, I am planning on a main menu of the four tapes. Each sub-menu will contain an entry for each day on the tape. I would also like to have a Play All option.
Unfortuneately, price is an issue, as is time. I have a wife, two kids, a dog, a cat, 2 vehicles, and a 4-bedroom mortgage to support. Add to that a military career that regularly takes me away from home, and I'm not left with a lot of time to encode 50+ tapes, let alone learn complicated software.
I've tried Pinnacle Studio 8 and TDA, but their menus are either not flexible enough, or look plain ugly. I'm not looking for Hollywood style DVD flair; just something attractive.
Can anyone help?
Results 1 to 13 of 13
"Oh my GOD! We're in the hands of engineers!"
- Jeff Goldblum in Jurassic Park -
TDA is capable of reasonable menus, but like any authoring tool, just how good it looks comes down to how talented you are as a creator.
As price is an issue, you could look at GUIforDVDAuthor. It is free, but it means you will have to prepare your menus assets (images etc) before coming in to create the menus. But you should be doing this with any tool.Read my blog here.
I'll admit that I'm not a graphic artist, but I don't like the way that TDA locks me into a certain number of menu items per page. Each of the tapes have a different number of days, and I would like each of the sub-menus to have a different number of items.Originally Posted by guns1inger"Oh my GOD! We're in the hands of engineers!"
You can edit this afterwards. There are also spec limitation - no more than 32 menu items on a 4:3 page, and no more than 16 on a 16:9 page.
You could also look at something like Ulead DVD Movie factory - http://www.ulead.com/dmf/runme.htmRead my blog here.
How do you edit it afterwards?
The best software out there, that I've found is Sony Vegas and DVD Arcitect. It is AWESOME! I've never seen such a powerful program be that easy to learn. It'll take a little to figure out at first but overall simple compared to some other programs. It's not as simple as some of the other programs like Photodex Proshow and some others but this one lets you customize EVERYTHING!!! I would suggest that you try these 2 programs out (they're linked to work together). The only downfall is that these programs are expensive. Good luck.
www.omaradesigns.com -
Sony Vegas and Adobe Encore DVD (I couldn't get into DVD Architect for some reason)
Agreed about DVD Architect - it seems very cumbersome for anything but the simplest drag'n'drop work. Encore has some serious issues that it has yet to overcome, including the fact that it does not recognise all legal compliant resolution, is crash prone (although a lot more stable than version 1.x was) and sometimes transcodes compliant assets.
Read my blog here.
I'm encoding a mini test for my first DVD in Encore right now. When I used to use Ulead DVDWS2, I would do all my encoding in Vegas to m2v and ac3. Apparently, Encore uses the same MainConcept encoder that Vegas does so I'm just going to try importing avi's, setting my chapter points and using the encoder in Adobe to see what happens... I'll let you know.
Ok, just tested my first burned DVD with Encore. Perfect! No flaws, no issues whatsoever. I transcoded the AVI in Encore as opposed to Vegas and it worked just fine when I popped it into the DVD player. Quality is simply superb! I actually made a preset to match what the final length of the DVD will be, little over 2 hours, encoded it at 4790mbps, 2 pass I think it was and it looks just great.
Can anyone recommend a DVD authoring program that will fulfill my needs?
By smythotech in forum Authoring (DVD)Replies: 5Last Post: 17th Aug 2011, 18:37 -
Recommend a software for M2TS
By vid2me in forum Video ConversionReplies: 4Last Post: 26th Aug 2010, 16:30 -
Emergency Can anyone recommend a Solid authoring program?
By jbandy1 in forum Authoring (Blu-ray)Replies: 3Last Post: 27th Jan 2009, 13:51 -
Please recommend software
By ccm2 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2008, 12:23 -
Can someone recommend a good package for editing/authoring?
By bek in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2008, 17:20
