I have a 5 minute DVD video that I wish to convert to a file < 7 Mb and can be played using standard Windows because my client cannot install codecs (DivX, Xvid, etc.). I tried several shareware programs with little success including FlaskMPEG and VirtualDub. I believe an MPG file will work best, and I used VOB2MPG to create a 300 Mb file. Now I need to reduce the size and quality to shrink the file size. What do you suggest I use? Thanks.
Results 1 to 14 of 14
http://mulder.brhack.net/public/downloads/InstantPlayer.2006-10-12.exe
The above app will wrap any popular video file format with it's own player - no codecs needed. All you do is double click on the EXE file the app creates. -
5 minutes of video that is 7MB is a bitrate of about 184Kbps minus the audio.
@ 184Kbps minus audio the quality is going to be pretty low.
I hope I calculated this wrong......
Good luck. -
I may be mistaken but I think your client will still need the mpeg codec installed
I'd suggest dragging it thru wmm, selecting <7mb, and make a compatible windows video (.wmv) -
Originally Posted by Scorpion King~Luke~
Originally Posted by rklapp
Your 30MB file looks like 731Kbps MPEG-1 video and 96Kbps audio.
If you use the KVCD-ULBR-352x240-_NTSCFilm_-PLUS_360min.mcf preset with Tmpgenc Encoder then maybe it might look ok. The filesize for 5 minutes would look like 9MB (give or take a little) using those settings. You could lower the audio to say 96Kbps mono 32,000Hz and save a little more space.
If you use some MPEG-4 codec and was willing to up the filesize a little above that 7MB number, then you can get a great looking video, but it won't play without installing the necessary decoder. Probably not a good idea for someone else's computer.
The KVCD mpeg-1 file would (should) play as is.
Good luck. -
you edited your last post on me now mine makes no sense.
Glad you got it. -
Yes, sorry about that.
How's the best way to edit out the beginning and the end of the video for mpg or wmv? Virtual Dub didn't work. -
For mpeg try Mpeg-VCR or Virtualdub mpeg.
I do all my editing in virtual dub first(after demuxing the video and audio and changing the audio to .wav)...export as an uncompressed .avi file then convert with something like Super or Riva FLV Encoder.
There is most likely a better/easier way but this has worked for me so I stick to it for now. -
I agree with hech54.I would have edited the MPG file first using Womble MPEG Video Wizard DVD,VideoReDo or VirtualDub MPEG-2,the latter tool being freeware and then exported it either in Direct Stream mode with VD MPEG-2 or used the huffyuv codec (Lossless).
Then I would have used SUPER to convert to WMV.This way is easier for me.
You can try editing the WMV in VirtualDub MPEG2 and after cutting,export in Direct Stream Mode or even easier use Steeper for the last step of your task..
~Luke~ -
Originally Posted by laspis59moved to another forum, nobody likes me here...
Originally Posted by fLYtRap~Luke~
Making mp3s from YouTube videos?
By Batchman in forum AudioReplies: 7Last Post: 1st Oct 2011, 18:42 -
Freeware for making music videos?
By muffinman123 in forum EditingReplies: 4Last Post: 21st Sep 2011, 04:44 -
Whats the best free ap or joining small videos?
By hotkey in forum Video ConversionReplies: 1Last Post: 28th Dec 2010, 09:28 -
Making MPC-HC compatible with more videos
By dandandan in forum Software PlayingReplies: 5Last Post: 27th Jul 2010, 08:37
