I use dbpoweramp which is excellent for MP3/FLAC/APE (11-band equalizer). Used it for a year. Sometimes when I open up any file (jgp, avi, etc.) or a Windows folder dbpoweramp stops for a second. Started happening a few mths ago. Is this because of not enought RAM or virtual memory? I have 768 MB RAM and 1250 MB virtual memory. I have upgraded versions of dbpoweramp but dbpoweramp people say there shouldn't be any bugs, etc. I usually multi-task all the time, too and don't have any problems with applications.
Windows XP SP2
Athlon XP 2700 Thoroughbred
ABIT mobo FSB333
Maxtor 60 GB HDD
350W PS
Well it seems that you have enough RAM and I cant imagine that dBpowerAMP would need that much anyway.Is 768 MB of RAM actually free or is it just the total amount you have installed? The reason I ask is that other apps,like at system startup could be hogging most of your installed memory leaving little for other programs.
Have you already uninstalled and reinstalled or posted this issue on the forum?
It might be that your operating system is playing you up if others dont complain of the same issue you described.~Luke~
encode cuts video ?
By stefniamoo in forum ffmpegX general discussionReplies: 1Last Post: 25th Jul 2011, 14:25 -
Audio cuts in and out
By the0ryyy in forum EditingReplies: 1Last Post: 15th Feb 2011, 17:41 -
MeGUI Cuts...
By MegaTonTerror in forum Video ConversionReplies: 4Last Post: 31st Jul 2009, 18:17 -
Question why edges cuts off
By tofuguy in forum Authoring (DVD)Replies: 2Last Post: 26th Oct 2008, 03:09 -
Audio Cuts out With GotSent on 5.1
By Calippo in forum Video ConversionReplies: 6Last Post: 4th Feb 2008, 20:29
