Anyone have any luck with encoding for the Meizu M6 with ffMPEGX?
The closest I have gotten is
video:
384 kbs 320 x 240 18fps
audio:
as a 128kbps MP3 48000 Hz VBR or ABR (Constant bit rate the audio is out of sync (early) a lot, maybe a second)
The problem is the audio.
It is always early. Using VBR or ABR for the audio instead of a CBR setting gets it closer to right, but still not great.
Any ideas?
Also, can you rotate videos in FFMPEGX?
Meizu seems to have the option to do this in the Windows software that ships with the device, based on Vdub I think (by the way, the audio is out of sunc when using their software too).
Audio is in sync on a PC though, just out of sync on the player.
Thanks for any help here.
-The Doc
Results 1 to 1 of 1
