Hello,
I've got a question related with ColorMatrix, CCE 2.70 and Rebuilder. I've seen that NaN and others (in other forum) recommended to use it to correct the colorimetry, but reading through the thread they talk about progressive DVD's.
My question is what should I do if I find an interlaced DVD. Until now, I've been adding just this, independently if the source was progressive or interlaced:
ColorMatrix(mode="Rec.601->Rec.709",hints=true).
I've done a search through this forum and manomo said to a user that is doing a conversion from a DV tape that he should add (interlaced=true).
So if the same apply with a dvd, then I should analyze first the dvd and if it is interlaced put this line?:
ColorMatrix(mode="Rec.601->Rec.709",hints=true,interlaced=true)
and if it is just progressive put this one as I did until now?:
Thanks in advance.
Results 1 to 1 of 1
Should audio track be smaller after DVD Rebuilder/CCE?
By hiimbored in forum DVD RippingReplies: 3Last Post: 22nd Jan 2009, 09:10 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 04:20 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 11:56
