When joining the 2 avi, dubbing into 2 minutes the file was 1.6 gigs... While the 2 avi add up to only 400 megs... Can someone help me ?
Sounds like , if using virtual dub, you may not have enabled compression for audio or maybe even video.
What are you using to join and what type of avi? i.e. mpg4, divx, dv avi, etc..
ZtR -
If your using avi's made from .vob files with vfapi, then in virtual dub use direct stream copy instead of full processing mode. If this is the case then you can't delete the vobs until you are done encoding and everything has worked.
joining avi
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2010, 07:13 -
Joining AVI files
By nycdude in forum EditingReplies: 6Last Post: 20th May 2009, 23:03 -
Joining avi's
By Frisco656565 in forum Video ConversionReplies: 5Last Post: 9th Sep 2008, 21:29 -
joining avi's
By php111 in forum EditingReplies: 15Last Post: 5th Aug 2007, 10:05 -
Joining two AVI's???
By Kayfabian in forum EditingReplies: 1Last Post: 17th May 2007, 18:07
