Please, I brought this model to brazil, but here we donīt know any kind of decondig system or code to unblock all the regions of the DVD, I really will aprecciate if someone know the correct procedure to unlock this model.Sony SLV-D271P
Samuel[/quote]
Do you have a DVD burner? You could set it to region 4. Then you could use DVD Decrypter to make a backup. The backup should play in all 8 regions.
Some region 4 use PAL and some use NTSC. If your region 4 DVDs use PAL then that could be a problem.
hack for sony SLV-D281P in region 1
By jimtone in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Aug 2011, 14:04 -
Sony SLV-D360P region free unlock codes?
By adriansherman in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Apr 2011, 13:39 -
Multi-region code needed for Sony SLV-D380P
By Rick Sailors in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Jul 2010, 21:29 -
Sony SLV-D380P
By Fede in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Sep 2008, 10:42 -
Region free Sony SLV-D271P & Philips DCP850/37
By famitsudc in forum DVD & Blu-ray PlayersReplies: 6Last Post: 14th Sep 2007, 10:38
