  1. Hello, i have a movie, about 3.06GB on an iso file.I 've downloaded the iso file...
    I have also downloaded the subtitles of the movie, both in srt and sub "form".
    I have nero burning rom 7 and deepburner and i want to burn the movie (iso file) with the subtitles (srt or sub) so i can play it on a regular dvd player (in my TV).
    THX in advance !
  2. Banned
    Freedonia
    You can't. An ISO file is an image file and can't be changed. I would suggest that you download and install Daemon Tools, mount the image, use a DVD ripping program to rip the video and audio into separate files and re-author with Muxman. I think you will have to conver the subtitles to SUP before re-authoring. Look at the guides here on how to add subtitles to DVD and they will tell you how to use Muxman. IFOEdit can also be used to re-author the DVD if you prefer to use it instead of Muxman.
  3. Banned
    Nov 2006
    Russian Federation
    Hi,
    Speaking about burning soft I suppose ISO-Burner is a really useful tool. It is very small but easy to use and realiable(never failed me). You might like it too
    spammer
