I have a uncompressed DVD on my hard drive with a working menu and it is too big for DVD shrink to take on. How can i lower the audio bitrate from 448 the easiest? Anyway to do this and still keep my working menu?
At 448kbps, I assume it is 5.1 AC3 audio. If you want to keep the 5.1 then you have demux the audio track from the DVD, demux the 6 mono tracks from within, re-encode at a lower bitrate - 384 kbps is about as low as you can go for 6 channels, remux it into the DVD, and realise you have save three tneths of bugger all, and it still wont fit. More can be saved by going to 2 channel at as low as 192kbps, but we are still onlt talking about saving maybe 200mb.
If it is that big then you really need to look at an alternate solution. The only viable one for a single layer disc is DVD Rebuilder with CCE or ProCoder. If it is that important to you, burn it to DL instead.Read my blog here.
Will DVD rebuilder be able to make a good looking movie from the DVD files i have? I am OK with dropped the bitrate to stereo at 256
Best way to reencode mpeg2 to lower bitrate
By justcurious in forum Video ConversionReplies: 3Last Post: 22nd Nov 2011, 17:05 -
Reencoding VC-1 WMV at lower bitrate
By casimps1 in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 22:34 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
4+hour DVD9, lower audio bitrate for better video?
By sdsumike619 in forum AudioReplies: 10Last Post: 24th Oct 2007, 11:24 -
Bitrate always comes out lower?
By MrMors in forum Video ConversionReplies: 6Last Post: 1st Jun 2007, 07:37
