I'm trying to make a complication DVD and whenever I decrypt the disc, I got this error message:
and then sometimes if it works in DVD Shrink I'm able to rip certain parts of DVD's I want.. then when I don't, I decrypt the disc and then do it in TMPEGenc DVD Author and I usually get that message when it's the VOB files that were decrypted.. but if it works it won't allow me to put the DVD Shrink VOB's in w/ the DVD Author VOB's.. is there a way to do this and get the DVD to burn? every time I try it's giving me lots of problems.. I'll even get this message.
thanks in advance for the help
well the first one is easy. It seems that you have a 50FPS video. TMPGEnc author does not re-encode the video for you. You have to do it prior to loading it in author. Use TMPGEnc Free and convert the mpg to a DVD video file. Usually bad header file means that header says the video is 20 mins 20 seconds and the actual video is like 20 mins 10 seconds.
Problem with DVD Author
By JCWBobC in forum Authoring (DVD)Replies: 1Last Post: 12th Jul 2009, 02:55 -
Tmpeg DVD Author doesn't like low quality captures?
By the wordsmith in forum Video ConversionReplies: 9Last Post: 20th Mar 2008, 07:30 -
Does TMPEG DVD author support multi VTS
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 17:19 -
why subtitles move with TMPEG DVD Author
By Konde in forum Authoring (DVD)Replies: 0Last Post: 22nd Jul 2007, 01:21 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 05:31
