What I'm trying to do is print vertical and horizontal writings on the spine of the DVD covers I make. On the spine of the cover, I'd like to put in horizontal the title of the DVD on the center, and then make a vertical text or graphic on the very top or bottom of the spine. I use a program called DVD and CD Cover Print. It's a very simple cover maker which is what I want but I want to be able to load vertical and horiztonal text on the same spine. Below is an example of what I'd like to do.
Results 1 to 11 of 11
I use one of the few products from Ahead that actually do what it claims to - The Nero Cover Creator. Any text at any angle anywhere.
/Mats -
I use Photoshp to do all of my covers. What applications do you have available?
Hell, even MSPaint can put text on any angle you want.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Settings? What setting could possibly prevent you from printing on the hub?
Perhaps you have a masking layer that is preventing you from printing in the hub area.
My PhotoShop template has a mask layer (in white) that sets the outer edge, and three different mask layers that set the inner edge. I have three inner mask layers, because I have hubbed DVD, hubless DVD and hubbed CD-R blanks available. Of course, only one is used at a time.ICBM target coordinates:
My personal favorite label/disk/case design software, SureThing Labeler (www.surething.com) will do that easily. The program creates a "box" for each text or graphic element that you enter, and each "box" can be placed anywhere, sized, and rotated as you please.
Edit:
My bad, I failed to read the subject title -
Originally Posted by OldAmateur
Originally Posted by strongbad
DVD Covers - What Paper?
By Nitro89 in forum MediaReplies: 12Last Post: 15th Apr 2009, 18:02 -
DVD covers
By Seasonal in forum Off topicReplies: 3Last Post: 3rd Mar 2008, 18:30 -
DVD Covers
By Beefer in forum MacReplies: 7Last Post: 15th Nov 2007, 14:17 -
dvd covers sizes
By ssaamm in forum Newbie / General discussionsReplies: 7Last Post: 14th Nov 2007, 17:59 -
HQ DVD Covers Before There Release
By twiggy99 in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2007, 14:01
