hello...i need help...i want to burn a multi-episodes dvd, and i need to add subtitles...i know there are a lot of guides out there to do so..but i would really like a faster way...heres what i do:
I first stick the subtitles to the avi using tmpgnc (this takes like 3 hours), and as my output file i get my audio an video (2 files), then i use these in dvdlab pro and burn it...
this takes a long long time..i was wondering if any of you knows of a program like dvdlab pro, that allows me to directly add my multiple avi files, select subtitles and just burn it....since dvdlabpro only works with mpg and vob...
thanks
Hello!
You can use ConvertXtoDVD, thats a terrific program, but only allows you to add the subtitles and do a simple menu.
Good luck -
can i add multiple avifiles and subtitles for each with this program?
Originally Posted by impulse_16
/Mats
Problems when trying to add subtitles to MKV and AVI
By Gabriel_HS in forum SubtitleReplies: 4Last Post: 23rd Jun 2012, 11:18 -
Need a program to add subtitles to an mkv file
By adamf154 in forum SubtitleReplies: 1Last Post: 12th Oct 2010, 00:59 -
how could i add arabic subtitle to avi movie?? plz help!
By abuelbeel in forum SubtitleReplies: 1Last Post: 20th Apr 2009, 13:44 -
permanently add subtitles to avi
By RZ_29 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2009, 09:57 -
How to add subtitles to AVI?
By sepehr_s in forum SubtitleReplies: 1Last Post: 16th Apr 2008, 14:10
