    May 2006
    my friend have a Sony VAIO PCV-RS720G Desktop PC, i took the S-video/RAC thing which is a pci card home. i find the driver online.
    and now i need a software i tryed VirtualDub, iuVCR, WinTV2000, VirtualVCR, Cyberlink PowerVCR, software but none of them work. i through that pci device dont work on my computer but i used the VLC media player and i plug my PS2 in it and the only problem is that you can feel the delay when u press a bottom, the video and the audio works fine.
    Is the delay a hardware problem or the software problem? if anyone know how i can fix the delay that will be good, but if you can give me a software that works fine and can also record that will be great.
    here is a picture of the Hardware
    http://img132.imageshack.us/img132/3...apocketoh6.jpg
    top:
    8-597-913-00
    BTF-PA402Z SONY
    MAKE IN CHINA
    T 4J04BS
    bottom right:
    CONEXANT
    MPEG II A/V ENCODER
    CX23416-22
    0423Y1TB
    0421 TAIWAN
    is called "Sony MPEG RealTime encoder board" in device manager
    is called "SMRT Capture" when detected by a software
  2. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVRS720G&UpdateType=Everything
    All the drivers for your friends machine.
    Many computer manufacturer's put thir drivers online. Their site should be the first place you look.
