Have been having problems with the last 2 or so updates of RipIt4Me. Starts ok, but then seems to stall after reading the first large VOB file. Keeps decreasing speed until down to zero and then just sits there, clock just keeps counting.
Even the previous version gave me errors. Dropped back to 1.4.1.3 and works fine. Don't know if it is the FixVTS lastest versions or the RipIt4Me latest versions. Anyone else have any problems. Was backing up "Click" at the time. I use Instant Copy to create the ISO file and if won't create the ISO I know there is something wrong with the Shrink file.
Ended up using DVDDecrypter and worked fine. Have done hundreds of backups and normally no problems--not until these latest upgrade versions.
Any help appreciated.
I'm having the same problem on some DVDs. For those DVDs, I use DVDFab Decrypter. Make sure you have the latest copy. You may also want to go back a version or so until the problem is fixed.
Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic
Ripit4me
By gjordan12198 in forum Newbie / General discussionsReplies: 11Last Post: 5th Jun 2008, 21:38 -
RipIt4Me ??
By rcguy1 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2008, 18:32 -
Looking for ripit4me.
By benzboy in forum DVD RippingReplies: 5Last Post: 20th Feb 2008, 14:46 -
A question about Ripit4Me
By mijman in forum DVD RippingReplies: 4Last Post: 17th Jan 2008, 15:44 -
Ripit4me site
By mickish in forum DVD RippingReplies: 58Last Post: 14th Jun 2007, 04:06
