I have a screensaver that I would like to convert to avi so that it can be used as a background on some dvd menus. I found a previous discussion on this and one idea was to use "snagit" to capture it. Is there a better way? thanks
Any screen recorder, basically. Which one is better I don't know.
/Mats -
I failed to mention that the screensaver is animated(movie) with sound. Maybe that makes a difference.
yeah, what should we use?
And what can I do with a screen recorder, and where can I find that program? -
Originally Posted by PTsniper
/Mats -
Originally Posted by mysts
Heh, quite a few screensavers are animated with sound.(dodges tomatoes)
If cameras add ten pounds, why would people want to eat them? -
Greetings:
I have the same interest to convert scr file to avi,mpeg,mwv format, so I can understand.
1). I have a sotware screenmaker 3d. It produce beautiful 3d cubes with photos that rotate etc as well as produced 3d tex which is aniumated. But it is saved in scr file.
2). The object is to get that scr file into a video editor like movie maker, or roxio of video wave or which ever video editing program or maker that one has. Normally, they will take avi, mpeg mwv, rm, to name but a few of the major foprmats.
3). Now as for the screen capture software, I have used several and maybe not a mush as others, however I have found that for capturing screen shots they are excellent quality. Howeverever when it comes to capturing movements such as scr file or other movie images (Not still shots) the results are not as sharp and clear. There are patches like water on the outcome.
4). Even by tampering with your harware excellerator during the capturing with the screen captures software, the quality is not as should be expected.
5). There shold be somewhere outthere a software taht actually accepts the scr file and then coinverts it into a selected number of roermats that one wants to use. This would bring about a clearer output file and this file then you could put into any of the video editing or video creation programs together with whatever slide or movie you wish to creat.
So, yes tehre are screen captures outtehre but unless you can find one that will provide excekllent quality from the movie scr images taht you are tryiong to capture, we must locate a proper conversion software. I have searched for all combinations of the words scr conversion to avi, mpeg, but every time I come up with a hit, the sofwtare only creats scr files. It does not convert!.
So if there is anyone out there who might have knowledge and a reply for this post, could you kindly help out here.
Thanks.
Tiger155 -
You are never going to get great quality trying to screen-cap screensavers. Most screen cap programs just aren't built for full frame, full frame rate capture. Many screen savers also put a lot of load on the system, depending on what they actually do. The example of the 3D cube - it may not be a video, but done live in realtime. This means a good load on the CPU, and also, no resource to extract because the scr doesn't actually contain the video, just the code to retoate a mapped cube in 3D.
Read my blog here.
Convert video to .scr (Screensaver)
By fitch.j in forum Video ConversionReplies: 9Last Post: 27th Jun 2012, 11:56 -
Looking to convert scr files (screensaver slideshows) to avi or mpg format
By wiltonp in forum Video ConversionReplies: 1Last Post: 23rd Jun 2008, 17:28 -
scr to swf or avi or mpg
By faithcopeland in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2008, 01:05 -
Convert Screensaver to Video?
By p_l in forum Video ConversionReplies: 8Last Post: 14th Jun 2007, 00:21 -
Convert screensaver files to some form of movie?
By michaelmcgennan in forum MacReplies: 3Last Post: 27th May 2007, 08:41
