I want install additional DVD Rom (I have CDROm). What not clear: is there some shortcomings/drawback of using two CDRom/DVDRom devices on one PC? Meaning affecting on system stability, on motherboard reliability, other. Normal use supposes to have one CDRom or DVDRom device per motherboard, however.
There is no disadvantage or problem. As long as it fits in your computer and your power supply is adequate, no problem. Lots of people have either a DVD burner and a second DVD-ROM drive (reader) so they can do copies, or two burners. Today, burners are so cheap few people bother with a DVD-ROM reader, and put two burners in. It's a good idea that at least one of the burners be a Master drive. If you have a SATA hard drive installed, you can set both burners as Master, one on the Primary IDE cable, one on the Secondary IDE cable.
Who says that's normal use. Many manufactuers package two optical drives.
Depending on the other devices on the system you may run out of DMA channels. If so make use the CD-ROM is uses PIO not the DVD.
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 14:40 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 18:22 -
Playing NTSC on PAL DVDRom?
By th3obr0 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Feb 2009, 00:18 -
Archiving DV.avi to DVDROM
By dgpretzel in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 14:53 -
directly connect my cdrom/dvdrom to tv
By d_unbeliever in forum ComputerReplies: 2Last Post: 1st Mar 2008, 04:02
