  1. HELLO,
    I RECENTLY ENCODED A DIVX WITH TMPGE, AND WAS ABLE TO BURN TO DISC... I USED NERO 5 TO CREATE A VCD FORMAT... AFTER BURNING THE CD, I DO NOT HAVE ANY VIDEO!!! THE AUDIO SEEMS OK, BUT I CANNOT VIEW THE MOVIE ON MY HOME DVD PLAYER. MY PLAYER SUPPORTS VCD, CDR, AND OTHER FORMATS, SO THAT IS NOT THE PROBLEM... CAN SOMEONE PLEASE TELL ME WHAT I AM DOING WRONG???? I AM PRETTY NEW AT THIS ALSO...... THANKS A LOT!!! THIS SITE IS GREAT!!!!!
  2. Last time I had this problem it was because I hadn't installed the correct codec. I had to install the 'smr' codec. Try previewing your file in Tmpgenc before you encode it. If you can see the video while previewing in Tmpgenc, thats not your problem. If its black also in Tmpgenc, try installing another codec.
  3. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    \THANK YOU... I WILL TRY THAT... I BELIEVE I HAVE THE SMR CODEC ALREADY INSTALLED. WILL RE-TRY!!!! THANKS!
  4. FIRST OF ALL PLEASE STOP YELLING!!!
    second of all DivX can NOT play on your stand alone dvd payer
    third please feel free to click on any of the great tutorials to the left detailing capturing, converting, editing, and authoring video cd's that play in a stand alone dvd player that supports written media
    peace out,
    dumwaldo
    AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
