Hi to all,
I just Got this Player player which has some small bug and im sure the FW could be improved so much. Does anyone already modified the firmware for this player?
I made a full divx test
My FW
Version 12.06.36.24
Subversion 00.00.04.05
8032 05.00.06.05
Servo 89.05.20.00
RISC 05.00.06.05
DSP 07.03.00.58
Region 2
Immagine/Display
 D/A converter: 12 bit, 108 MHz
 Picture enhancement: High Def (720p, 1080i), Progressive scan, Smart Picture, Video Upsampling, Video upscaling
Sound
 D/A converter: 24 bit, 192 kHz
 Signal to noise ratio: 100
 Distortion and noise (1kHz): 85 dB
 Crosstalk (1kHz): 100 dB
 Dynamic range (1kHz): 90 dB
 Sound system:: Dolby Digital
 Frequency response:: 30-20,000 Hz
Video playback
 Playback Media: CD, CD-R/CD-RW, CD/SVCD video, DVD, DivX, DVD+R/+RW, DVD-R/-RW
 Compression formats: MPEG1, MPEG2, DivX 3,11, DivX 4.x, DivX 5.x, DivX 6.0, DivX Ultra
 Video disc playback system: PAL, NTSC
Audio Playback
 Playback Media:: CD, CD-MP3, DVDMP3,CD-R/RW, WMA-CD
 Compression format:: Dolby Digital, MP3, PCM, WMA
 MP3 bit rates: 32 - 256 kbps
Still picture playback
 Playback Media: DVD+R/+RW, DVDR/-RW, CD-R/RW, CD immagini, CD immagini Kodak
 Picture compression format:: JPEG
 Picture enhancement:: Capovolgimento foto, Rotazione, Zoom, Presentazione con riproduzione MP3, Risoluzione ad alta definizione
Multimedia Applications
 Multimedia connections:: Dispositivo USB memory
 Playback formats:: DivX, MP3, Fermo immagine JPEG
Bug : Rewind always 32x
Bad: No Goto with Divx, slow in changing audio with divx (abt 2 seconds its mute)
Good: Audio Quality, Video. DVD menu wonderful, Foto eccezionali e velocissime nel caricare
Video Test
Lastmanstanding
Menu no
Audio 3
Subtitle 3
DIVX Test v2.0
14 Characters
File Option
OPT-3C = Yes (MP3 ID3 v1 tag display)
OPT-3D = Yes Only Audio (MP3 ID3 v2 tag display)
File-Images
IMG-01 JPG 2 Megapixels Yes
IMG-02 JPG 6 Megapixels Yes
IMG-03 GIF No
IMG-04 BMP No
IMG-05 TIF No
IMG-06 PNG No
IMG-07 PCX No
Compatibility tests : MP3
AUD-1A mp3 2.0 48KHz 96Kbps CBR (simple mp3 test) Yes
AUD-1B mp3 2.0 48KHz 96Kbps VBR (VBR test) Yes
AUD-1C mp3 pro 2.0 48KHz 96Kbps CBR (SBR test) P (48khz detection = Yes, otherwise P) Segna 95kbps
AUD-1D mp3 5.1 48KHz 192Kbps CBR (multichannel test) Yes
Compatibility tests: AAC
AUD-2A LC-AAC 2.0 48KHz 96Kbps CBR (simple test AAC) No
AUD-2B LC-AAC 2.0 48KHz 96Kbps VBR (VBR test) No
AUD-2C HE-AAC 2.0 48KHz 96Kbps CBR (SBR test) (48khz detection = Yes, otherwise P) No
AUD-2D LC-AAC 5.1 48KHz 192Kbps CBR (multichannel test) No
Compatibility tests: WMA9
AUD-3A WMA9 Sdt 2.0 48KHz 96Kbps CBR (simple WMA9 test) Yes (segna 97kbps)
AUD-3B WMA9 Sdt 2.0 48KHz 96Kbps VBR (VBR test) Yes (segna 97kbps)
AUD-3C WMA9 Pro 2.0 48KHz 96Kbps CBR (WMA9 Pro test) No
AUD-3D WMA9 Pro 5.1 48KHz 192Kbps CBR (multichannel test) No
Compatibility tests: Ogg Vorbis
AUD-4A Ogg Vorbis 2.0 48KHz 96Kbps CBR (simple Ogg Vorbis test) No
AUD-4B Ogg Vorbis 2.0 48KHz 96Kbps VBR (VBR test) No
AUD-4C Ogg Vorbis 5.1 48KHz 192Kbps CBR (multichannel test) No
Compatibility tests: Others
AUD-5A AC3 5.1 48KHz 448Kbps CBR (simple DD test) No
AUD-5B DTS 5.1 48KHz 768Kbps CBR (simple DTS test) No
AUD-5C MPC 2.0 48KHz 96Kbps VBR (simple MPC test) No
AUD-5D FLA 2.0 48KHz (simple FLAC test) No
H_Compatibility : supported video codecs (all files included)
MPEG1 and MPEG2
VID-1A VCD MPEG1 1150 Kbps + MP2 224 Kbps (VCD standard with file only compatibility test) Yes
VID-1B SVCD MPEG2 VBR ~1150 Kbps (max 2520 Kbps) + MP2 224 Kbps (SVCD standard with file only
VID-1C KVCD MPEG2 VBR ~1150 Kbps (max 9800 Kbps) + MP2 192 Kbps (modified MPEG2 KVCD with file
VID-1D MPEG2 MP@HL HD 720p 1280*720*60 + AC3 2.0 224 Kbps (standard MPEG2 MP@HL 720p
compatibility test) No
VID-1E MPEG2 MP@HL HD 1080i 1920*1088*30 + AC3 2.0 192 (standard MPEG2 MP@HL 1080i compatibility
test) No
Microsoft MPEG4 (M$ MPEG4 V3, DivX 3.xx, DivX 3 NBC ...)
VID-2A DivX 3 + MP3 CBR (DivX3 compatibility test) Yes
VID-2B DivX 3 Bitrate Crash Test + MP3 CBR(crash test with 4 levels of complexity: write down the last supported bitrate) 6000 Ok
VID-2C DivX 3 High Definition 1280*720 + MP3 CBR (High Definition 720pcompatibility test) No (only Audio)
VID-2D DivX 3 High Definition 1920*1088 + MP3 CBR ((High Definition 1080p compatibility test) No (only Audio)
MPEG4 ASP (XviD, DivX4, DivX5, DivX6, 3ivX, NeroDigital ASP ...)
VID-3A MPEG4 ASP 4CC DivX + MP3 CBR ((simple DivX codec compatibility test)) Yes
VID-3B MPEG4 ASP 4CC XviD + MP3 CBR (simple XviD codec compatibility test) Yes
VID-3C MPEG4 ASP Bframes + MP3 CBR Write down the number of b-frames supported (1/2/3)
(multi-bframe without packet bitstream compatibility test) Tutti
VID-3D MPEG4 ASP Bframes packet bitstream + MP3 CBR Write down the number of b-frames supported
(1/2/3) (multi-bframe with packet bitstream compatibility test) Tutti
VID-3E MPEG4 ASP Custom Matrix + MP3 CBR (custom matrix compatibility test) Yes
VID-3F MPEG4 ASP Qpel + MP3 CBR (Qpel compatibility test) Yes
VID-3G MPEG4 ASP GMC 1 WP & 3 WP + MP3 CBR Write down the number of warp supported: 0/1/3
(GMC 1 & 3 warp points (DivX & XviD) compatibility test)) Tutti anche se al terzo scrive Risoluzione Video Non supportata
VID-3H MPEG4 ASP Bitrate Crash Test + MP3 CBR CBR (crash test with 4 levels of complexity: write down the last supported bitrate) 4500 Yes
VID-3I MPEG4 ASP High Definition 1280*720 (High Definition 720p compatibility test) No (only Audio)
VID3J MPEG4 ASP High Definition 1920*1088 (High Definition 1080p compatibility test) No (only Audio)
MPEG4 AVC (Nero AVC, x264, Quick Time AVC, MainConcept AVC, Sorensen AVC ...)
VID-4A MPEG4 AVC Main Profil + LC-AAC CBR (H264 Main Profile compatibility test) No
VID-4B MPEG4 AVC High Profil + LC-AAC CBR (H264 High Profile compatibility test) No
VID-4C MPEG4 AVC Bframe + LC-AAC CBR (multi-bframe compatibility test) No
VID-4D MPEG4 AVC Reference Frame + LC-AAC CBR (multi-reference frame compatibility test) No
VID-4E MPEG4 AVC Cabac + LC-AAC CBR (Cabac compatibility test) No
VID-4F MPEG4 AVC weighted prediction + LC-AAC CBR (weighted prediction compatibility test) No
VID-4G MPEG4 AVC with quantization matrix + LC-AAC CBR (Custom quant matrix compatibility test) No
VID-4H MPEG4 AVC Bitrate Crash Test + LC-AAC CBR 750/1500/3000/6000
(crash test with 4 levels of complexity: write down the last supported bitrate) No
VID-4I MPEG4 AVC High Definition 1280*720 + LC-AAC CBR (High Definition 720p compatibility test) No
VID-4J MPEG4 AVC High Definition 1920*1088 + LC-AAC CBR (High Definition 1080p compatibility test)No
Microsoft WMV9 or VC-1
VID-5A WMV9 MP@ML + WMA9 sdt CBR (WMV9 compatibility test) No
VID-5B MPEG4 AVC Bitrate Crash Test + LC-AAC CBR 750/1500/3000/6000
VID-5C WMV9 MP@HP High Definition 1280*720 + WMA9 sdt CBR (High Definition 720p compatibility test)
No
VID-5D WMV9 MP@HP High Definition 1920*1088 + WMA9 sdt CBR (High Definition 1080p compatibility test)
No
I_Compatibility : video containers ans « bivx » tests (all files included)
AVI Containers
CONT-1A MPEG4 ASP + MP3 2.0 48KHz 96Kbps CBR (simple AVI container compatibility test) Yes
CONT-1B MPEG4 ASP + MP3 2.0 48KHz 96Kbps VBR (mp3 vbr audio-video synch test) Yes
CONT-1C MPEG4 ASP + AC3 5.1 48KHz 384 Kbps CBR (multichannel test) Yes  Low volume
CONT-1D MPEG4 ASP + Multiple MP3 2.0 48KHz 96Kbps CBR (MP3 multi audio test  3 audio tracks) Yes
CONT-1E MPEG4 ASP + Multiple AC3 5.1 (multi-audio with multichannel AC3 test  3 audio tracks) Yes Low volume
CONT-1F MPEG4 ASP + MP3 2.0 48KHz 96Kbps CBR + Multiple subtitles (AVI subtitles test  3 subtitle tracks)Yes
CONT-1G MPEG4 ASP + MP3 2.0 48KHz 96Kbps CBR + chapter (AVI Chapter test  3 chapters) Yes without Chapters
CONT-1H MPEG4 ASP + Multiple MP3 2.0 CBR + Multiple subtitles + Chapter + Menu (AVI menus test) Yes Without Chapter e Menu
CONT-1I MPEG4 ASP + DXAudio 2.0 CBR (DivX audio test = old WMA) Yes
CONT-1J MPEG4 ASP + Multi DXAudio 2.0 CBR (multi-audio with DivX audio test)  3 audio tracks) Yes
DivX Container (DivX6 standard)
CONT-2A MPEG4 ASP + MP3 2.0 48KHz 96Kbps CBR (simple DivX container compatibility test) Yes
CONT-2B MPEG4 ASP + MP3 2.0 48KHz 96Kbps VBR (mp3 vbr audio-video synch test) Yes
CONT-2C MPEG4 ASP + AC3 5.1 48KHz 384 Kbps CBR (multichannel test) Yes Low volume
CONT-2D MPEG4 ASP + Multiple MP3 2.0 48KHz 96Kbps CBR (multi-audio with MP3 2.0 test  3 audio tracks) Yes
CONT-2E MPEG4 ASP + Multiple AC3 5.1 (multi-audio with multichannel AC3 test 3 audio tracks)  3 AC3 tracks) Yes Low volume
CONT-2F MPEG4 ASP + MP3 2.0 48KHz 96Kbps CBR + Multiple subtitles (Divx6 subtitles test  3 subtitle tracks)
Yes Subtitlei out of screen
CONT-2G MPEG4 ASP + MP3 2.0 48KHz 96Kbps CBR + chapter (chapter test  3 chapters) Yes without Chapters
CONT-2H MPEG4 ASP + Multiple MP3 2.0 CBR + Multiple subtitles + Chapter + Menu (divx6 menu test) Yes without chapter e Menu
MP4 Container (MPEG4 official standard, Nero Digital)
CONT-3A MPEG4 ASP + LC-AAC 2.0 48KHz 96Kbps CBR (simple MP4 container compatibility test) No
CONT-3B MPEG4 ASP + LC-AAC 2.0 48KHz 96Kbps VBR (AAC VBR audio-video synch test) No
CONT-3C MPEG4 ASP + LC-AAC 5.1 48KHz 192Kbps CBR (multichannel AAC test l) No
CONT-3D MPEG4 ASP + Multiple LC-AAC 2.0 48KHz 96Kbps CBR (multi-audio AAC test 2 audio tracks) No
CONT-3E MPEG4 ASP + Multiple LC-AAC 5.1 48KHz 192Kbps CBR (test du multi-audio en AAC multicanal  2
pistes) No
CONT-3F MPEG4 ASP + LC-AAC 2.0 + Multiple subtitles (Nero Digital subtitles test  2 subtitle tracks) No
CONT-3G MPEG4 ASP + LC-AAC 2.0 + chapter (chapter test  3 chapters) No
MKV Container (Matroska)
CONT-4A MPEG4 ASP + MP3 2.0 48KHz 96Kbps CBR (simple MKV container compatibility test) No
CONT-4B MPEG4 ASP + MP3 2.0 48KHz 96Kbps VBR (test de synchro audio-video avec MP3 VBR) No
CONT-4C MPEG4 ASP + AC3 5.1 (multichannel AC3 test) No
CONT-4D MPEG4 ASP + Multiple MP3 2.0 48KHz 96Kbps CBR (multi-audio MP3 2.0 test  3 audio tracks) No
CONT-4E MPEG4 ASP + Multiple AC3 5.1 Eng (multi-audio iwith multichannel AC3 test  3 audio tracks) No
CONT-4F MPEG4 ASP + MP3 2.0 48KHz 96Kbps CBR + Multiple subtitles (Matroska subtitles test  3 subtitle
tracks) No
CONT-4G MPEG4 ASP + MP3 2.0 48KHz 96Kbps CBR + chapter (chapter test  3 chapters) Y No
OGM Container
CONT-5A MPEG4 ASP + Ogg Vorbis 2.0 48KHz 96Kbps CBR (Simple OGM container compatibility test) No
CONT-5B MPEG4 ASP + Ogg Vorbis 2.0 48KHz 96Kbps VBR (Ogg Vorbis VBR audio-video synch test) No
CONT-5C MPEG4 ASP + Ogg Vorbis 5.1 48KHz 192Kbps CBR (multichannel Ogg Vorbis test) No
CONT-5D MPEG4 ASP + Multiple Ogg 2.0 48KHz 96Kbps CBR (multi-audio with Ogg Vorbis 2.0 test  3 audio tracks)
No
CONT-5E MPEG4 ASP + Multiple Ogg Vorbis 5.1 (multi-audio with multichannel Ogg Vorbis  3 audio tracks) No
CONT-5F MPEG4 ASP + Ogg Vorbis 2.0 48KHz 96Kbps CBR + Multiple subtitles (OGM subtitles test  3 subtitle
tracks) No
CONT-5G MPEG4 ASP + Ogg Vorbis 2.0 48KHz 96Kbps CBR + chapter (chapter test  3 chapters) No
WMV Container (Microsoft standard)
CONT-6A WMV9 + WMA9 sdt 48KHz 96Kbps CBR (simple WMV container compatibility test) No
CONT-6B WMV9 + WMA9 sdt 48KHz 96Kbps VBR (WMA9 VBR audio-video synch test) No
CONT-6C WMV9 + WMA9 pro 5.1 48KHz 192Kbps CBR (multichannel WMA9 test) No
CONT-6D WMV9 + Multiple WMA9 sdt 2.0 48KHz 96Kbps CBR (multi-audio stereo WMA9 test  2 audio tracks)
No
CONT-6E WMV9 + Multiple WMA9 pro 5.1 48KHz 96Kbps CBR (multi-audio multichannel WMA9 test  2 audio
tracks) No
J_Compatibility : separated subtitle files tests (for *.avi containers)
(all files supplied except SUB-09 and SUB-11)
SUB-01 SubRip .srt without tags Yes
SUB-02 SubRip .srt with tags Yes
SUB-03 MicroDVD .sub Yes
SUB-04 SubStation Alpha .ssa Yes
SUB-05 SAMI .smi Yes
SUB-06 SAMI .smi multi-languages (2 languages) Yes
SUB-07 Original DVD subtitles .sub + .idx Yes
SUB-08 Multiple subtitles (SubRip in separated .srt files 2 languages) Yes
SUB-10 Display of accents/special characters Yes
SUB-12 Viewable Character lengths - Write the exact maximum number of characters displayed by line - 43
SUB-13 Number of lines displayed - Write the number of lines displayed during the test (1/2/3) - 3
16 October 2006
USB
Its ok, but only 8 characters and 2 folder level
If i have Trip->Brazil->Rio, San Paolo etc (all directory)
i will see all i have in Brazil directory, but i will not see the 2 dir Rio and San Paolo, their names tooi.
Tested
HD 250 Lacie Porsche: perfect
Pen Peak 1GB: perfect
Pean Peak 2gb 120x (new) : Nothing
I hope i copied all .
Thanks in advance
Alex
	I upgraded to firmware version 12.06.36.34. This version supports DTS stream output which is a major positive (to me). Some other issues like "no 5.1 sound when using HDMI" are solved too. To my knowledge there are no changes in the formats which it can / cannot play.
 QB
 PS In your specs I see "Region 2". There is a region 0 (all) hack available, I think it is even posted on this site.
	Hi,Originally Posted by QubyB
 i found that, but do u know if i can switch again to Region 2? cause in italy we lose guarantee..
 PS: i uptaded something in the first message about the USB port
 cu
 Alex
	Does the version 12.06.36.34 firmware work OK?
 I have the 12.06.36.24 version on mine (also a R2 version in the UK) but have read several posts of dodgy firmware upgrades on the version numbers 37.xx.xx.xx - presumably the R1 version of the device.
 I've just started using HDMI and found pretty quickly that I've now only got PCM digital output which the latest firmware version is claimed to fix. But then again I don't want jerky playback instead. I had that on the previous Yamada 6700 which is why I got the 5960.
 Andy
	http://www.phunkyfish.com/article/4/philips-dvp-596012
 For all modded firmwares etc...
  Philips DVP5960 and USBBy lets in forum DVD & Blu-ray PlayersReplies: 715Last Post: 10th Jun 2012, 11:03
  .mkv on Philips DVP5960?By Conrad007 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2009, 12:11
  philips dvp5960By tonie in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 15:58
  Philips DVP5960 or 5982?By siskiou in forum DVD & Blu-ray PlayersReplies: 11Last Post: 20th Apr 2008, 22:28
  Philips DVP5960 HelpBy clubfoot in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Sep 2007, 06:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
