Yes well, I'm trying to feed my extended basic cable into this TV Tuner but the end result is a big color bleed which doesn't show up on my normal TV. It looks a little better with the composite video, but then I don't have the controllability. Looks the same on WinTV and BeyondTV, and the tweak tools I've tried had no effect. Any other ideas?
Operating System: Microsoft Windows XP SP2
Processor: Athlon 64 3000+
Graphics Card: eVGA NVidia 6800 GT 256MB
Sound Card: Sound Blaster Audigy 2 ZS Gamer
Memory: 1GB Corsair DDR PC-3200 VS512MB400C3
Motherboard: Chaintech VNF3-250
Direct X: 9.0c
Hard drive: Hitachi Deskstar 7K250 160GB + Western Digital WD800 80GB
TV Tuner: Hauppage WinTV-PVR 150
Power Supply: Thermaltake Purepower 420W
Speakers: Creative Inspire P5800 5.1
Monitor: Gateway EV700
We're still waiting for the images to download! (ImageShack is really slow right now.)
It looks like one of the chroma channels isn't lined up properly. I have a PVR-250 and have never seen it do anything like that. I've heard of a few problems with the PVR-150 but again, nothing like that.
On the off chance that it is a display problem, capture a bit and then look at the MPEG file with VirtualDubMod or VirtualDubMPEG2. Those have their own MPEG2 decoders and don't use video overlay to display the image. If you see the problem there you know it's a problem with the the PVR-150 or the source. And if it occurs on all channels it's not the source. -
I'm getting the same thing with my PVR-150. The cable feed is going directly to capture card--nothing in between except a splitter. It happens on all channels. Shows up regardless of the mpeg2 decoder. I've tried dialing down the saturation, but the problem is so severe that it makes little improvement.
I've heard of chroma shift being introduced into the signal because of vhs recording, or composite connections, or bad s-video connections--none of this applies here. Can chroma shift be introduced because of bad cable or bad splitters? (I don't believe so, but please educate me if I'm wrong.) Also, I don't see this on any other tv tuners in my house.
Should I consider returning the card while I can, or is there a tweak for this?
Samples:
http://images23.fotki.com/v866/photos/1/10355/5049503/choma1-vi.jpg
http://images4.fotki.com/v50/photos/1/10355/5049503/choma2-vi.jpg
http://images23.fotki.com/v866/photos/1/10355/5049503/choma3-vi.jpg
http://images114.fotki.com/v879/photos/1/10355/5049503/choma4-vi.jpg
http://images6.fotki.com/v883/photos/1/10355/5049503/choma5x-vi.jpg
Capture Lossless with WinTV-PVR-150
By rudolf016 in forum Capturing and VCRReplies: 50Last Post: 28th Feb 2012, 11:39 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 21:07 -
Converting Hi8 for Mac using Hauppage WinTV PVR USB2?
By eamann in forum MacReplies: 7Last Post: 6th Aug 2009, 14:37 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 10:39 -
Blue screen when installing Hauppage WinTV 150 drivers from website
By ponyboy in forum Capturing and VCRReplies: 1Last Post: 5th Mar 2008, 22:55
