hi there!
could anyone help and point out a clear cut way
to do this:
i have a powerpoint slideshow file that i would like to
play on a commercial VCD player.what steps and software
must i make in order to author a slideshow with background sound and transitions from my ppt file.
is this possible? your help is highly appreciated.
thanks in advance.
If you don't mind losing your transitions. You could export your PowerPoint to all .jpgs and use Ulead DVD Pictureshow. Not sure but I'm sure you can export your sound to .wav and voila. VCD 2.0 which works in most DVD players.
If you want your slideshow on VCD, your transitions are history.
You can save the individual slides by setting the page size to 7.34" wide x 5" high and saving as a TIFF or JPG file. PowerPoint will save all of the sides at once and sequentally number them. Your slides should now be sized at 704x480, which is the hi-res spec for VCD. You can use the Phillips VCD Toolkit, VCDImager, or Nero to save the files to a VCD.
If you want to add sound to each slide, check out this guide:
http://www.vcdhelp.com/VCDslideshow.htm
RF -
ive read that article.
pls correct if im wrong,i understand that sound/music
per slide is different from background music?
how do i add continuous background music?
isnt there an avi/mpg author app that can add transition
to still images.can adobe premiere do this?
thanks for the responses guys! =) -
You can do transitions with moving images, but not still images. The only way to preserve your current presentation is to record it to video. You could use a VCR or another computer with a video capture card, provided you have a way of outputting the presentation to video.
RF -
You could also use a screen recorder program like HyperCam or Camtasia to record the PowerPoint presentation to an AVI file while it is playing. Then you could convert the AVI file to Mpeg and create a VCD. It wouldn't be a real slideshow but would basically be a movie of your PowerPoint presentation. However you would keep your transitions and audio.
HyperCam etc are resource hungry so you should keep the screen resolution to 640x480 or 800x600 maximum with 16-bit color and you may be limited in the framerate you can capture depending on the speed of your system.
Ironically Mac users have a much easier way to do this. PowerPoint on Mac has an Export to QuickTime option that lets you export directly to a QuickTime movie. You could then convert from QuickTime to Mpeg for VCD. Even the latest PowerPoint on Windows doesn't have a comparable feature AFAIK. -
thanks for the help guys!
i found out that roxio ezcd platinum has
arcsoft video impression.
it can create a movie from stills and has transition
effects like powerpoint...plus background music!
powerpoint to quicktime---that's neat. Mackies have all
the fun. -
If you use a slideshow with your stills turned into video clips though, you are limited to a screen resolution of only 352x240/288 for VCDs which is entirely insufficient if you want to display any sort of detail (e.g., text).
SVCD is better with a resolution of 480x480/576 but it still doesn't compare to standard VCD hi-res still images. This is something you have to consider.
Regards.
Michael Tam
w: Morsels of Evidence
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 03:18 -
Slideshow Help
By GuyinBrown in forum Authoring (DVD)Replies: 4Last Post: 27th Oct 2009, 21:38 -
What's the best-easily working program to rip sound from vcd ?
By billyww in forum AudioReplies: 1Last Post: 20th Jan 2009, 06:30 -
Slideshow with sound in sync
By tin2tin in forum User guidesReplies: 0Last Post: 18th Jun 2008, 04:07 -
Slideshow question
By jjis in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 02:27
