Both my first and replacement NEC ND-3550A burner will not recognize TDK CD-RW blank media. It's using the Windows XP SP-2 Driver 5.1.2535.0. It will recognize other brands of blank CDs and my Lite-On CD burner does recognize the TDKs. I tried 10 of the 25 in the new cake stack. Both NEC burners are from Newegg. Can anyone please advise me? It is important to me to be able to use CD-RWs.
What are you burning with?
See if the drive recognizes that media with DVD Identifier (free)
What firmware version does your drive have? -
This was a OEM Newegg pkg. I thought the Firmware was 1.05. I use Roxio Creator 7. It reconises all brands of DVDs and other CD-R blanks.
Newest firmware is 1.06. Try upgrading that. Also be aware that some drives just don't like certain media. If your TDK isn't MIJ then it might be a good idea to try something else anyway.
FYI, you can use Liggy's 1Y6 or 1.06 Bitsetting firmware if you want to be able to bitset DVD+Rs. Essentially, this is the 1.06 firmware modified to support this. It's not NEC firmware though. -
Thank you very much. I can't tell if my TDK cd-rw's are MIJ. It doesn't say. Where would it say, its not on the label? I don't want to ruin this burner with firmware that's out of the 'box' so to speak. I asked newegg and they will let me exchange the second Burner as well. So I think I am going to take them up on it. Thanks again for the help.
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 07:16 -
Blank DVD Media
By jason in forum Newbie / General discussionsReplies: 21Last Post: 2nd Dec 2008, 12:40 -
Blank media revisited
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2008, 10:57 -
Really, really weird issue with NEC 3550A
By ioannisds in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st Jul 2007, 15:07
