I am not sure why this is happening, but I recently downloaded the x264 codec revision 590, when I double click the file to install the codec, the only thing that happens is I see the command prompt pop up on the screen and then disappear. I have .net framework 2.0 on my computer, as it says this is needed. Is there something else I am missing?
Results 1 to 10 of 10
You probably downloaded the x.264 command line encoder program, not an installable codec.
when i did a search on yahoo i went to free-codecs.com and downloaded what was available , it showed screenshots for it, anyone know where to download an the x.264 installation file
i am a little confused. If i want to select the option in gordianknot to use x.264 what file am i suppose to download and how do i install it to my system. i recently reformated my hardrive and thought i kept an installation of an x.264 installer file that worked with gordianknot, but I cant seem to find this on the net anymore
Download the MEGUI from the same kink...
http://www.free-codecs.com/download/x264_Video_Codec.htm -
Mediacoder and Staxrip will also work. I don't see an h-264 option in my copy of AutoGK.
Try this link for an older VFW version:
http://mirror02.x264.nl/x264/revision573/x264-573-install.exe -
GK uses VfW which was removed from x264's SVN. Basically if you want to use GK for x264 (not recommended) then you would need to use an old VfW build or checkout an older revision with VfW, then manually build a new VfW build.
Personally I stopped doing VfW builds ages ago and all other builders would have stopped now and people who use VfW tend to not have the skills to compile stuff. -
thanks, I really appreciate how fast you guys responded. i figured out how to use megui with the new builds of x.264. when converting the audio to the different available options, do i have to install the codecs in a certain folder, or were they installed with megui. for example if i wanted to convert the audio to mp3 using lame. thanks again
How to make x264 codec do 16:9?
By brassplyer in forum Video ConversionReplies: 3Last Post: 27th Oct 2011, 17:17 -
I want use x264 codec in virtualdub but i can't
By Hugo12317 in forum Video ConversionReplies: 5Last Post: 6th Jun 2011, 13:41 -
I can't figure out how to use the h.264 (x264) codec!
By Tahlos in forum Newbie / General discussionsReplies: 9Last Post: 15th Jun 2010, 18:34 -
VirtualDub doesn't see x264 codec.
By olegk in forum Video ConversionReplies: 7Last Post: 9th Jun 2010, 02:10 -
Color problem with x264 output + other x264 questions
By serexl in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 18:31
