I知 only interested in doing conversions from HDTV .tp/.ts files to DVD. I知 more interested in the sound AC3 quality be untouched, then picture quality. With that info, what would I gain by moving/upgrading to SVCD2DVD when I知 now using HDTV2DVD? I see that the new version just released up弾d the bit-rate to 9M from 7.8M, what else would I gain from using SVCD2DVD instead of HDTV2DVD?
ThymeJ
Depends on what you are doing.... If you are putting a 2 hour movie onto DVDR then you will only see the bitrate benefit. If you are putting an episode of CSI from HDTV to DVD then with SVCD2DVD you can put 2 on there (with or without a menu)... maintaining the high quality you have already seen...
That is correct.Originally Posted by thymejSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
SVCD2DVD crashes, HDTV2DVD runs ok
By silicon101 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 11th Jul 2011, 16:32 -
HDTV2DVD 0.4 Vista
By CathyT in forum Authoring (DVD)Replies: 2Last Post: 28th Dec 2009, 13:01 -
HDTV2DVD does not load up TS-file
By feilofix in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2008, 14:25 -
New Tool: HDTV2DVD
By ChrissyBoy in forum SVCD2DVD & VOB2MPGReplies: 270Last Post: 2nd Jul 2008, 23:05 -
How to load .ts file into HDTV2DVD?
By JR.S in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 02:59
