Hi folks,
I just started using AVIDemux 2 and I'm wondering if you can create a list of selections, that could be output to single file? Currently, all I can do is set the start and end points for a selection and then output that bit of video to a file - so if I want to multiple selections in one AVI, I then need to go back and join all of the various selections I individually wrote.
Any advice?
-Zero
You should do it the other way around :
select the parts you want to REMOVE and then ctrl X
repeat
At the end you are left with only one chunk (the one you want)
Save
Avidemux
By BaPW in forum EditingReplies: 7Last Post: 24th Jan 2012, 23:22 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
please help me with avidemux
By phoenix777 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Sep 2011, 04:18 -
Avidemux
By jjis in forum Video ConversionReplies: 1Last Post: 23rd Nov 2009, 17:38 -
AviDemux....again...
By diablo_jones999 in forum Newbie / General discussionsReplies: 5Last Post: 10th May 2008, 08:31
