Using mainconcept (adobe) it took over 4 hours to transcode about half an hour of DV footage, after I had capped it to the HD. Is this about how long it takes? are their programs that are faster, I did 2 pass progressive. So is this just how long it takes? or can it be faster with the same quality results?
Jeff
P.S. Almost forgot the most important part, I'm on a 2.0ghz pentium M, 1gb RAM
Sounds a bit too long - I'd expected half that. CCE is the fastest encoder around.
/Mats -
Unless you are doing massive filtering, your system should be able to give you 1X speed. So two passes times 30 minutes should have only taken you 1 hour.
You also did a progressive encode. Are you sure that your DV is progressive?ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Originally Posted by SLK001
Jeff
advantages of transcoding mpeg2
By codemaster in forum EditingReplies: 4Last Post: 26th Apr 2012, 16:11 -
deinterlacing source mpeg2 when transcoding it to dv
By codemaster in forum EditingReplies: 14Last Post: 20th Apr 2012, 13:18 -
Split MPEG2 at exactly time !
By *Baby* in forum EditingReplies: 2Last Post: 25th Sep 2009, 10:06 -
Estimates of labor and parts to fix color of Sony HDTV
By edong in forum Newbie / General discussionsReplies: 11Last Post: 28th Nov 2008, 22:41 -
Time Lapse help, mpeg2 from AVCHD
By cjbrown80 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2008, 08:26
