Hi, am looking for some help in transferring vcr to pc.
I have a life view fly-tv card fitted and have succesfully transferred from 8mm camcorder to pc. I'm now trying to transfer vcr across, problem comes with what connections to use from vcr to pc, I have a scart to rgb with audio/video connections (used on sony playstation) but when this is connected I get no picture.
The software is pretty easy to use and has options for cable/satellite tv etc but picks nothing up when "AV in" selected.
I ve uploaded the connection diagram for tv card to assist anyone.
Any help is appreciated on this and apologies if any info is lacking.
Cheers
keith666,
from the picture you supplied (obtw, cudos for you it sure makes life easier), I think you have two options.
Option 1: you can use the composite video cables (the red, white, yellow connectors) to connect your vcr to your video input card. Most vcrs have composite "output" connectors.
OR
Option 2: you can use the S-video route. However, there are not many vcrs that have an svideo "outpput" connector. The ones that I have seen only have an S-video input connector. But the others do exist. Hopefully, you have one of those. If not sure check you manual.
Then all that is left is to:
1: set your capture software to record from the composite or S-video inputs (as applicable)
2: fire up your capture software on the pc,
3: plug in a vhs tape and
4: hit play on the vcr then record on the pc capture software or record on the capture software then play on the vcr.
Hopefully, you will have achieved success.
Ed -
I'm assuming your RGB is the three cable output with red, green and blue jacks? If so, no that won't work with your video card. As edsmith77, said though, you should have a composite output (Normally yellow) along with your regular stereo audio (Red and white) outputs.
I'm not too familiar with SCART, but maybe you need a different adapter.
And welcome to our forums.
Thanks for the help, will continue to try and should (hopefully) be succesful.
cheers
Problem connection HDD to TV
By WinSpecToR in forum DVB / IPTVReplies: 8Last Post: 19th Feb 2012, 13:16 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
t.v. connection problem
By brenda1906 in forum Newbie / General discussionsReplies: 10Last Post: 27th Mar 2010, 08:18 -
Wireless Connection Problem
By StoneColdWhat in forum ComputerReplies: 4Last Post: 8th May 2008, 00:38 -
Problem with internet connection
By Wizard23 in forum ComputerReplies: 5Last Post: 11th Sep 2007, 12:18
